system relay chatter
Old Sep 29, 2017 | 05:58 PM
Davgo's Avatar
Davgo
Stage II
Default system relay chatter
2010 dyna super custom. When i turn the ignition on the system relay starts chattering and won't let me turn the bike over. Any ideas on what would fix the problem, or a starting point for me to begin to try to fix the problem? I am not mechanically challenged so I can do the work no matter how indepth I need to go. I am starting a new job on monday so i am kinda pressed to fix this, any help would be greatly appreciated, thank you.
Old Sep 29, 2017 | 07:19 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Um.. have you tried replacing the relay? When I worked at a high end boat manufacturer wiring the helm stations, at times we would have a relay go bad during the final test, just happens. The coil inside just stops working. But for giggles and grins check your connections to the relay first.
By the way welcome from west side of Mi. next to the big lake.
Old Sep 29, 2017 | 08:41 PM
Davgo's Avatar
Davgo
Stage II
Default 2010 dyna
yes i have already replaced the relay and it is still chattering. thank you for the welcome and the advice
Old Sep 30, 2017 | 01:13 PM
seniorsuperglideE8
Have you checked the voltage on the battery, 12.8V min.? Check all the connections hot and ground to the starter. Have you done anything to the bike prior to this event?
To me sounds like there isn't enough voltage or a weak ground to hold it closed to allow a path for elec.
Old Sep 30, 2017 | 02:27 PM
j_bee's Avatar
j_bee
There are two chassis grounds immediately to the left of the battery/battery tray down in the recess under the seat.
Check that they are in good condition.
One of the larger wires coming off of the two chassis grounds also goes to the main engine ground located beneath the battery tray and behind the starter motor. Check that is in good condition also.
As already suggested, ensure the battery is good.
Good luck finding the problem and with the new job.
Old Oct 1, 2017 | 05:22 PM
tuner's Avatar
tuner
Are you sure it's not the fuel pump clattering?
Old Oct 1, 2017 | 11:16 PM
UKNixter's Avatar
UKNixter
I agree with checking your battery has a good charge. Same thing happened to me today while chasing a problem with my turn signals. Had them on for too long and drained the battery. Even at 12.73 volts you could hear the relay chatter, and hitting the started tried and then a heavy clang. Had it on the tender for a few hours and just tried it, fired right up with no noise except fuel pump.
Old Oct 3, 2017 | 12:14 AM
Max Headflow's Avatar
Max Headflow
Check battery voltage with ignition on.. It should be over 12V.
Blue Duck
Electrical/Lighting/Alarm
Sep 24, 2015 04:00 PM
Born2cure
Jul 14, 2013 08:55 PM
Rayzen
Jul 30, 2010 10:14 AM
brianseay
May 24, 2010 09:47 PM
philbo
Shovelhead
Jul 11, 2007 07:24 AM
