Bike won't start
Old Jul 13, 2013 | 01:08 PM
Born2cure's Avatar
Born2cure
Default Bike won't start
Happened to me few times starts great ride to store get out wont start. When I hit start it's like it is in 1st gear nothing happens. Lights everything ok voltage only 10 maybe 11. Twice it needed jump another time started after about an hour. I changed the battery still happens. when driving voltage is excellent. Any ideas?????
Old Jul 13, 2013 | 01:39 PM
kevin_n's Avatar
kevin_n
starter going bad? buddy of mine had the same problem with a 06 soft tail, replaced the starter and bike worked fine.
Old Jul 13, 2013 | 02:07 PM
mkguitar's Avatar
mkguitar
1.) sort out the charging system first- looks like there is a problem there
2.) jumped the bike?..well, if you did have a duff battery and jumped the bike...it is possible to over stress the charging system ( as it tries to recharge a duff battery) resulting in bad charging system. ( $100 problem becomes $400 problem)
so start with the charging system.
like always check and clean all wiring connections.
mike
Old Jul 13, 2013 | 04:37 PM
toothmansteveb's Avatar
toothmansteveb
Same problem with my 09. New starter fixed it.
Old Jul 14, 2013 | 06:44 PM
Born2cure's Avatar
Born2cure
Started great today road about 30 min came home tried no issues. Let it cool little went short ride 5-10 min radio blasting came home nothing sat couple min started right up. Checked all levels all good. Road another short ride came back nothing. Sat 20 min started right up. Should I invest in a starter. If so is ther a strong after market for the 08 ultra
Thanks guys
Old Jul 14, 2013 | 06:48 PM
mkguitar's Avatar
mkguitar
you don't "invest" in parts.
you spend on parts.
you could buy a starter...but what if the starter on the bike now is perfect?...could be money wasted.
and a yet to be discovered problem waiting.
correct diagnosis is the key to a reliable vehicle. otherwise it is just replacing parts- hoping for a fix.
that gets expensive fast
Old Jul 14, 2013 | 08:26 PM
jdvorchak's Avatar
jdvorchak
First thing to do is the cheap and easy stuff. Clean all of the electrical connections from the battery. Take the battery cables off, and clean them and where they bolt onto the battery. Remove the Negative cable and clean where it connects to the frame. Don't just blow on it! Clean the cable and where it attaches to the frame with a wire brush. Then follow the Positive cable down. Clean every connection that cable makes down to the starter. Again remove the cable and wire brush both connection points. When you have it all clean be sure and hook the Positive battery connection first then the Negative last.
I'll bet you find a loose connection while you're cleaning everything.
Old Jul 14, 2013 | 08:55 PM
smithbrl's Avatar
smithbrl
What does this mean?
dch_10680
Engine Mechanical Topics
Nov 8, 2014 11:09 PM
ArtR
Jul 7, 2014 09:19 AM
texashillcountry
EVO
36
Mar 21, 2012 09:55 PM
Gypsy Ann 77FXE
Shovelhead
Jun 30, 2010 12:41 PM
RYE BREW
May 30, 2009 09:08 AM
