1981 superglide electrical ignition troubles
Old Jun 5, 2007 | 12:31 PM
philbo's Avatar
philbo
1st Gear
Default 1981 superglide electrical ignition troubles
1981 Superglide with electrical issue(s). I have replaced battery, voltage regulator and solenoid this season.When attempting to start the bike yesterday I pressed the start button,the bike would not start.After the start buttonwasreleased the bike getting turning over. The battery had to be disconected in order to stop the bike from cranking. The solenoid began smoking. Any ideas? Starter relay? Baffled 2 weeks before bike week in NH, please assist.
Old Jun 5, 2007 | 01:12 PM
shovel pat's Avatar
shovel pat
Default RE: 1981 superglide electrical ignition troubles
http://www.shovelhead.us/specs/wiring.htm
Philbpo I dont know if this is any help or not. I would pull the wire off of the starter first, and then work your way back from there.... unwire solenoid and try it, see if relay sticks...unwire relay and see if its the switch. With the starter unwired, you can check for voltage without taxing your whole electrical system. Good luck!
Old Jun 5, 2007 | 03:40 PM
panz4ever's Avatar
panz4ever
Another quick thought,,,what kinda shape is the starter relay in? Seem like you've got juice going through your system when it should not. Any chance of faulty starter button. Have you re-wired anything as of late....starter, solenoid, relay, voltage regulator.
Old Jul 11, 2007 | 04:34 AM
jpooch00's Avatar
jpooch00
I had an '80 that did that same thing. Replacing the starter solinoid fixed mine - at least it never did it again after I replaced the solinoid.
Old Jul 11, 2007 | 07:24 AM
74shovel's Avatar
74shovel
low voltage will make the solenoid stick. I put a glass mat battery in my old shovel and can't believe how it starts. fantastic is the word for it
Cal516
Electrical/Lighting/Alarm
May 26, 2015 07:03 PM
maddghost
Sep 3, 2012 03:58 PM
jsa750k
EVO
Oct 8, 2011 06:02 PM
philbo
Jun 5, 2007 07:34 PM
telemorgan
Apr 17, 2006 01:02 PM
