Crossed wires while replacing starter
Old Oct 21, 2017 | 08:25 PM
JSeifert's Avatar
JSeifert
Stage II
Default Crossed wires while replacing starter
First post so please bare with me.
This morning I began changing my starter (2003 fxd). I got the starter bolted up and went to reconnect the battery. When I put the cable back to the negative post, smoke and a little fire sparked up near the front right foot peg. It turns out I hooked one of the 2 negative cables to the hot post on the new starter and then the hot battery cable to the starter bolt along with the other negative cable. I took it all back apart and hooked it up right, but now my dash is blank and it seams all electrical is dead. I pulled the battery out, looked at the fuses, checked voltage at the battery (13ish V) and am stumped on where to look next.
Any help or ideas are appreciated.
Old Oct 21, 2017 | 09:23 PM
Vec's Avatar
Vec
did you check the main fuse?
Old Oct 21, 2017 | 09:56 PM
JohnMn's Avatar
JohnMn
that,,
Old Oct 21, 2017 | 10:02 PM
TexasScooterTrash's Avatar
TexasScooterTrash
Well, you fried some wires. Before you start any other "repairs" to your bike, GET A SERVICE MANUAL! You will need it to check all of the wiring in the starter circuit. You may have also fried the battery. Lesson #1, if you've never done it before, use some masking tape and mark where each wire is connected BEFORE you take it apart. Makes reassembly a no-brainier.
Old Oct 21, 2017 | 11:34 PM
JSeifert's Avatar
JSeifert
Stage II
Thanks for the help. After reviewing some wiring diagrams, I noticed I had wires connected to the starter mount and one to the hot post. I rearranged the wires again and it started up.
Old Oct 21, 2017 | 11:47 PM
JohnMn's Avatar
JohnMn
Good for you,
Hey, we all make some silly mistakes from time to time,, glad you found an issue you could fix
Stay safe out there,,
88sports
Electrical/Lighting/Alarm
Oct 9, 2016 10:00 AM
teeboz
Sep 4, 2013 01:50 AM
Bohemian
Shovelhead
43
Jul 9, 2013 10:37 AM
ozzie65
Feb 25, 2009 09:59 AM
PJsthnam
Mar 29, 2006 05:33 AM
