Thanks too Mchad...
I now wish I had went with 16 inch bars... But the 14 with 3 inch risers work too..
My thing is to whom ever reads this unless you do the work yourself. Check behind the person that works for you Every bolt, double check. Its becoming sad the no one has pride in the work they do.
Due to my not so good tech skills the image didn’t come through correctly..page 142 item 8. Above the all models section says “Tighten riser fasteners to 30-40 ft-lbs (40.7-54.2 Nm).”
So I’m good and so will the OPs after he redoes the HD techs work. ;-)
Just wanted to make sure he had the right number. Thanks!
