oil change help
Old Jun 15, 2007 | 09:38 AM
sidewayzz's Avatar
sidewayzz
5th Gear
Default oil change help
Its a 01 wide glide.which one is the oil drain plug? Should bike be level when refilling or on the kickstand? How many qts does it hold. I ordered a manual,but it aint here yet. Just picked the bike up last week and want to get it ready for a poker run Sat. Thanks, Steve
Old Jun 15, 2007 | 11:24 AM
SUPER01's Avatar
SUPER01
Default RE: oil change help
The oil drain plug should be at the front of the motor right by the spring for the kickstand.
2-1/2 quarts then then check oil level on the kickstandafter running it.
Hint for the oil filter.
Use a 2-liter bottle to catch the oil, cut the bottom off and slice the side to fit over the oil filter so you can fit your hand/fingers in to twist off filter.
Have a good time.[sm=biker.gif]
Bluraven
Sep 12, 2021 04:18 PM
djkolp
Sep 2, 2019 03:44 PM
pontiac69
Apr 29, 2011 11:41 AM
broadwayjoe
May 18, 2007 04:04 AM
