Replacing handlebar levers on 2017 Dyna Street Bob
Hey everyone.
I bought new clutch and brake levers for my Dyna, but I'm having trouble finding removal/installation guides in the Dyna service manual and online.... what gives?
I see some tutorials that include draining the transmission fluid and rewiring all the cables just to install new levers. Is this accurate?
I'd also appreciate a handlebar replacement guide if possible. I do not need to re-run the wires because I plan on replacing a 10" bar with another 10".
Thanks in advance!
Matt
Thanks in advance!
Matt
For the levers, there is a little “C” clip on the underside of the housing, remove that, push the pin out and the lever just pops out...sort of.
Clutch side, you have to Give the cable some slack, turn the adjuster so that the cable is really loose, then do the clip, pin and pull the lever out. Pretty simple when you look at it.
If you have a parts manual it will show you how it looks....
Received 5,401 Likes
