steering/fork stabilizer
Old Feb 8, 2018 | 04:25 PM
adamsrotors's Avatar
adamsrotors
Default steering/fork stabilizer
looking for a bolt-on, non-top clamp/triple tree style stabilizer for a '17 FXDLS.
having hard time finding for (if it exists) with direct fit. anyone have some tips/links?
Old Feb 8, 2018 | 05:02 PM
adamsrotors
nvm...I was just using the wrong key words! "steering damper"
found a few options, but happy to hear ideas/experience.
feel free to delete if you want tho, mods.
Old Feb 8, 2018 | 06:14 PM
misfitJason's Avatar
misfitJason
The storz one is the best. The other ones tend to leak
Old Feb 8, 2018 | 08:10 PM
TOE_CUTTER's Avatar
TOE_CUTTER
https://www.gprstabilizer.com/find-k...ears=2016-2017
Dave
Old Feb 9, 2018 | 02:15 PM
adamsrotors
^ specifically stated, not interested in triple tree/top clamp style.
I pulled the trigger on the Drag specialties one. $280...can't justify almost double for the storz, for a gold anodized end cap. will report back!
Old Feb 9, 2018 | 02:32 PM
fxdx_ftw's Avatar
fxdx_ftw
drag specialties and Storz are not close in quality, hence the price difference
Old Feb 10, 2018 | 10:49 AM
TOE_CUTTER's Avatar
TOE_CUTTER
Missed that. I take it you are getting one because of exceeding 120 mph. The stock suspension S models are not too bad up to 120. Getting a component based on it being cheaper when it can cost you your life or a huge hospital billl is your choice.
If you are getting it for show, then go for it.
IMO,
Dave
Old Feb 10, 2018 | 11:42 AM
adamsrotors
I'm getting it because this bike is insanely unstable on the freeway, coming from a street glide...smaller tires, less weight...a small pothole almost killed me, let alone cross winds with my tall fairing.
and no, anything stock from harley, suspension-wise is junk. swapped out with Ohlins day one.
I wanna try this route first and see how I like it, otherwise, yes...the top clamp option will be what I go for.
you guys, it's piston/shock. this isn't an issue about poor quality vs. premium...it's all the same mouse trap. unless it's total Chinese ****, or more so old/crap seals, it's going to be fine. like I said, I'll report back, but I'm telling you right now, I'd bet Storz is using the same damn shock body.
Old Feb 10, 2018 | 12:55 PM
fxdx1985's Avatar
fxdx1985
I’ve been looking too. Interested in report.
Old Feb 10, 2018 | 01:38 PM
2500hdon37s's Avatar
2500hdon37s
a steering damper wont help you much.
You need a Vibratechincs predator motor mount.
on dynas the swing arm is mounted to the transmission/ engine case which is only supported in the frame by two mounts, so the front mount moves side to side in the frame. Which allows the bike to be unstable and wobble in corners. The vibratechnics motor mount doesnt allow side to side motion.
