***FXDX won’t start***
Old Feb 8, 2018 | 11:16 PM
fxdx_ftw's Avatar
fxdx_ftw
Default ***FXDX won’t start***
recently pulled the outer and inner primary. Installed new inner primary bearing and new drive belt. Put it all back together tonight and CLICK CLICK CLICK. Bike will not turn over. Battery is reading fine. 2002 FXDX. I have read this problem somewhere else online. Something binding?
Old Feb 8, 2018 | 11:44 PM
im's Avatar
im
Guessing you are checking battery with a digital voltage meter.
What is the voltage reading at battery? If you have less than 12.4 volts then it is low.
Old Feb 9, 2018 | 04:39 AM
Campy Roadie's Avatar
Campy Roadie
IF you verify that battery voltage is up to standard, consider this:
You pulled the outer and inner primary which means you had take apart the starter shaft and gear to get it out. Pull the outer primary and verify you put it back together correctly or it won't engage the ring gear on the clutch basket. Start with 47 and work your way out.
Old Feb 9, 2018 | 06:15 AM
fxdx_ftw's Avatar
fxdx_ftw
yes, checked battery with multimeter. At 13V.
Old Feb 9, 2018 | 07:29 AM
fxdx_ftw's Avatar
fxdx_ftw
I feel like something is out of alignment. We were rocking the bike back and forth while clicking the starter button while in gear. One time it wanted to kick over, then went back to the constant clicks. ANY IDEAS?
Old Feb 9, 2018 | 02:41 PM
fxdlx's Avatar
fxdlx
you checked the ground post nut down by the starter? Cleaned up the battery connections?
Old Feb 9, 2018 | 03:00 PM
fxdx_ftw's Avatar
fxdx_ftw
yes, it’s not like a relay click. Its the “plunger” a loud audible click. Everything was fine prior to the primary being taken apart. After we put it back together this happened.
Old Feb 9, 2018 | 03:24 PM
Campy Roadie
Cough, cough...post #3
Old Feb 9, 2018 | 03:29 PM
fxdx_ftw's Avatar
fxdx_ftw
going to pull outer primary and check starter in about an hour
Old Feb 9, 2018 | 03:58 PM
skinman13's Avatar
skinman13
What is the voltage across the battery when you push the start button? If that is dropping down to around 10 volts, then that would indicate that the starter winding is getting current flow from the battery and the problem is probably mechanical. If the volts are not dropping when you push the starter button, that would indicate the start circuit is not completing to engage and run the starter suggesting a wiring or starter problem.
Good luck!
