Breaking tail light bubs...
I searched the forums and couldn't find an existing thread, so I thought I'd start a new one and ask you guys:
My '08 FXDL has gone through 2 tail light bulbs in 9 months. The bulbs didn't burn out, rather, they shattered!
1 of the bulbs was a conventional/incandescent and I cleaned it with rubbing alcohol before reassembling the lens cover. The last bulb was this LED: https://www.superbrightleds.com/more...fit/3557/7523/
The mounting plate on the fender is pretty tight and not moving around. Any insights on why these things popping would be appreciated!
Thanks!
Can you post a picture of the bulbs?
Way-out-in-the-weeds but .... tail light comes on as soon as you turn on the ignition, starts getting hot.
Is it possible then somehow it gets hit with cold water?
You're in LA ain't no snow ... wtf.
Yeah, its totally weird!
Unfortunately, I didn't take a pic, but all of the pieces were rattling around inside the lens/housing and it sounded like a bartender making a cocktail with ice in a shaker. The bulb bases were fine and were solidly plugged in when I removed the lens.
You're right about my location - LA and its been completely dry and I haven't splashed through any significant puddles.
This may be an equally long shot, but I wonder if it had to do with all of the bumps in these local canyon roads? They're pretty rough - almost as choppy as a fire road - and perhaps I shook the living daylights out of the bulb? I know that LEDs are way more durable than incandescent because there isn't a glowing filament, but I can't think of any other reason?
My FXD was going through three headlights a year until I switched to HID and my right side pegs will work lose if I don't check them regularly but the left side is never lose.
Did you check the lens interior for melted plastic at point that bulb glass might touch?
For example, if someone put a high heat bulb like a halogen at some point then the lens could have melted in the interior center creating somewhat of a spike.
Thinking that glass tip of bulb might be touching lens...with vibration it would be like a constant hammer on the glass from lens.
Thanks IM! Its definitely OEM and the interior is unmarred. Same for the softer rubber-y mount that the bulb passes through - it all appears to be fine.
Like Robottom and yourself, I thought heat was the culprit (it may have been for the incandescent bulb) but I can't image that would be the case for an LED?
Perhaps Skinman's observation is culprit - vibrations & shaking affecting a working bulb made it pop?
We used to remount the bulb base and try to turn the filament 34-45 degrees... that sometimes worked. I was not able to do that with my headlight, though. Cheap or expensive bulbs made no difference. I replaced everything but the bucket and ring but one of the beams would go out after about 100 days, like clockwork. I have had the HID system on for about 6 months and so far it is working great.
I once put red Locktite on my highway pegs before a long trip and still it came lose. I swapped the bolts and mounts from left to right and it still came loose.
Same for autos. If you replace an OEM headlight, lots of times, the last two numbers on it are LL. The one you usually get after market won't have it on there and you will be lucky to get 1/3 the time out of it. Some even put it on the package but it's not on the bulb.
LL suffix is Long Life. There are also heavy filament (and glass) options for off road and rough use. Some are even laminated with silicone or plastic to help prevent shattering from impact.
