O2 Sensor
Old Mar 26, 2018 | 01:43 PM
Andy02's Avatar
Andy02
Default O2 Sensor
I recently moved into a new place and for the life of me, I can't seem to find my FSM so I'm coming to you guys for a little help. Bike is a 2015 Street Bob that has been popping and backfiring some. Pulled the codes and got all kinds of **** that lead back to O2 Sensors. So, I started the bike while checking sensor data on both O2 sensors. At idle, my forward O2 Sensor is reading 0.8 volts while my rear is reading 4.9 volts. Obviously, one of the sensors took a crap but without my FSM, I don't know what the actual reading should be. Anybody able to help me out a little?
Old Mar 26, 2018 | 06:07 PM
dlporter's Avatar
dlporter
Which codes did you pull? With AFR set at 14.6, O2 sensor voltage should be about 0.45 volts. Your rear O2 could be the culprit. But remember an O2 sensor is just that, a sensor. There could very well be another problem and the sensor is working as designed.
Old Mar 26, 2018 | 08:05 PM
Nickd2689's Avatar
Nickd2689
i could be wrong, but I was under the impression they should read between .5-4.5 volts. I’m a Chrysler tech and automotive o2s read in millivolts, but all other sensors normal range is between .5v and 4.5v. Generally less than .5v and above 4.5v is when there’s an issue.
It isn’t likely that both of them are bad but one of the ways I diagnose o2s is by taking a propane or map gas torch, and connecting a hose from the end of the torch to the air intake then turning the gas on slightly while the bike is running. Since the gas is occupying the space of air, your bike should run lean and your o2 voltage should go low. Then if it changes, remove the o2 sensor, and run the bike while slowly moving it away from the o2 bung. Now the voltage should increase.
It’s not nearly as much work as it sounds, and it’s an easy way to determine if they’re fun ruining correctly. Both o2 sensor readings should be close to the same. If you do this, and the o2s respond correctly, you’ll want to start looking at your injectors. I like to swap injectors and see if the bad o2 reading switches cylinders. Sorry for the long reply, hopefully this helps a little
Old Mar 26, 2018 | 09:24 PM
dlporter's Avatar
dlporter
The 0.45 volts number came out of the electrical and diagnostics manual. The manual makes the assumption that the AFR is set at 14.6 at idle, which I believe the stock maps probably are. The manual has a progression of troubleshooting methods to determine if there is a ground, then to check the operation of the sensor. At the end of the troubleshooting progression, assuming you rule out other mechanical issues like fuel injectors or intake leaks, harley has you either replace the O2 sensor or the ECM depending on what the sensor voltage is reading.
Old Mar 26, 2018 | 09:42 PM
Nickd2689's Avatar
Nickd2689
very interesting and well explained. Learn something new everyday. Thank you for the explanation. 95% of this stuff functions the same as automotive components but every once in a while I learn of something that does not.
Old Mar 27, 2018 | 10:30 AM
Andy02's Avatar
Andy02
I don't remember what all the codes were. They all had to do with cylinders running rich or lean and one for an O2 sensor voltage. I cleared them and then started the bike while watching the sensor data. I know that it may not be the sensor at all but they are relatively inexpensive and pretty easy to change so I'll change it and if the problem persists, go from there. Thank you for taking the time to look for me.
bellmnbell
Dec 8, 2016 07:18 PM
hdkev
Aug 12, 2014 12:41 AM
KCFLHRC
Nov 5, 2011 12:07 AM
rodney123456
Jun 30, 2011 07:21 PM
vdubpig
Dec 8, 2006 12:29 AM
