88 ci engine temp.
Actually, no the heat isn't a prob. Just wondering about ET, but thanks anyway.
Now here's a question..
Oil cooler is located on the down tubes 6 to 8 inches of the ground?
Oil filter relocated to down tube having filter 12 to 18 inches off the ground and away from the motor?
Is this a wash? Will both cool the same?
Not the same. Oil cooler has openings that let the air through which essentially blows over the oil cooling it down. No openings in a filter.
Now to be fair, an oil filter in the air, getting actual airflow over it , might cool down the oil a little more then being tucked beside the engine but I run a proper oil cooler so I won’t be the one to find this out.
Bucket list Trike
Oct 30, 2014 12:07 PM
