Hello everyone
Old Apr 17, 2018 | 01:04 PM
laptopbob61's Avatar
laptopbob61
Stage III
Default Hello everyone
Im Robert Ribble from Missouri aka laptopbob61 i just got my first iron horse last week and already turning a wrench. its a 2000 Dana Super Glide, when riding with some friends i was told my brake lights were staying on so i came here for advise on my findings. i already left a commit but don't know where it went so i will leave another one here. what i found was the wire loom came loose from broken plastic clip under rear fender and tire rubbed through the loom and into the wiring was wanting to know if they offer a metal clip for the loom to prevent this from happening again.
Old Apr 18, 2018 | 12:21 PM
nevil's Avatar
nevil
If your suspension is lowered the tire makes contact with the fender a lot easier than if stock. Even if the shocks are stock you wouldn't want a metal clip that can dig into the rear tire.
There a a few members here that worked around that problem, so hopefully someone will chime in.
Old Apr 18, 2018 | 04:27 PM
cggorman's Avatar
cggorman
I've seen everything from bent tubing to foil tape. Kinda depends on how handy you are and what methods or materials you're comfortable with.
Zip tie anchors (either epoxied or 3M double stick)
Metal or plastic tube (either solid or slit lengthways) fixed to fender by epoxy, JB Weld, or whatever.
Weather proof tape (hvac foil, etc)
Assorted industrial metal or plastic anchors from places like McMaster-Carr
Even alternate wire routing and/or lighting.
Previous owner of my 99 did a lot 2 up riding with standard shocks and that wiring was TORE UP from multiple repairs over many seasons. I guess he got so tired of messing with it that last repair was just cheap hookup wire, twisted & and taped. Lol.
Old Apr 18, 2018 | 05:00 PM
laptopbob61
Stage III
i ended up using the org. tabs with plastic wire ties to hold the loom from slipping out of clip a little bit of a pan but we'll have to see how it works out thanks for your responces
Sal C
Oct 13, 2012 09:46 AM
HotIceHD
Jun 25, 2012 08:43 AM
danzio
Oct 24, 2011 03:06 AM
albngore
Jan 24, 2011 07:17 PM
bakerm75
Jan 29, 2009 03:40 PM
