Battery Problem, Please Help Me :(
Old Apr 20, 2018 | 11:04 PM
skinman13's Avatar
skinman13
Originally Posted by jackietan
When I hit the start, it drop to 9.5v and back to 14.2v around 2800rpm
9.5 volts is too low for your bike. It will most likely fail a load test.
Get a new battery and don't put a tender on it during riding season unless it is going to sit for more than a couple of weeks, then only for a few hours.
Old Apr 20, 2018 | 11:11 PM
lh4x4's Avatar
lh4x4
" The stock HD batteries are garbage. "
Really!!! Then why do I get 6 to 9+ years out of the H-D batteries in the 24 bikes in the garage? Just had to do two 2012 bikes this month. A 12 V Rod and a 12 RGC CVO. 6 years has been the least so far. Traded a bike at 9 years and the battery was strong.
Old Apr 28, 2018 | 07:00 AM
DFA821's Avatar
DFA821
Default 9 + years
When the HD battery was redesigned for model year 2000, that battery was going 10 years right out of the box! In 2009 HD went to the manufacturer and asked them to dumb down the battery since they did not have enough aftermarket sales. In my years in the battery industry I have seen this first hand with the warranty claim data from the HD dealers. Good battery maintenance is also key to keeping the battery lasting for years. The new HD batteries since 2010 are lucky to last beyond 2 years. If you are looking for a replacement battery, the Interstate product would be the best choice. As long as it is made in the USA. Some are imported from China. Interstate does the best job in making sure the products that their dealers sell are kept up to date.
Old Apr 28, 2018 | 07:08 AM
Ron750's Avatar
Ron750
Being in Wisconsin my bike sits half the year. I hook it up every month, for one day, to my Batteryminder. I bought my ‘03 in ‘11, I don’t know how old the battery was. I replaced it in 2015 when I had trouble starting, but it was really a bad ground, battery was fine. The Extreme battery I bought, which is supposed to be the same as the stock is still fine.
I think it was leaving your lights on that fried your battery.
Old Apr 28, 2018 | 09:55 AM
STRES's Avatar
STRES
Just get this one, I had roughly the same issues as you same bike 2014 FXDB
Yuasa YUAM720GH GYZ20HL Battery
Amazon Amazon
AMAZON says it won't fit, but fit like a glove, and I get better cold starts due to the higher CCA's
Old Apr 28, 2018 | 02:49 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Just read some info on the CTEK MXS5.0, step one desulfation. A battery will create sulfides on the plates as it being used up, during the desulfation process it would seem the sulfides are being forced off the plates and now in suspension in the acid medium in the battery. Dragging the battery down real low compounds the issue till the sulfides go plate to plate and short out cells, killing a battery. According to HD manuals 12.7V is 100%, after sitting for 2 hrs after complete charge, no load.
Old May 5, 2018 | 06:00 AM
jackietan's Avatar
jackietan
Thank you for the information. I bought the Harley Davidson battery, will be careful to switch off the emergency light next time again and put on a few hours tender if not ride of a couple of week.
Old May 5, 2018 | 06:08 AM
Ron750's Avatar
Ron750
Make sure you tighten the terminals. I recommend using battery protector spray.
Amazon Amazon
Old May 5, 2018 | 06:36 AM
jackietan's Avatar
jackietan
https://www.amazon.com/Permatex-8037.../dp/B000BOKML2
Thank you. I apply some dielectrical grease.
Old May 5, 2018 | 03:39 PM
nevil's Avatar
nevil
The tender is designed to be kept on all the time when the bike is parked. It is not a battery charger.
