switches
Old Apr 25, 2018 | 06:02 AM
Frédéric CM's Avatar
Frédéric CM
Default switches
Hello guys,
The other day, I noticed the right hand switches (blinker, starter,..) are moving Inside the housing...
I opened the switch housing but everything is tight (there is 2 small torx screws on the lower halve). As soon as I tighten the top halve of the housing, something make the switches become loose and move (1-2mm, enough to make to top the blinker switch rub against the housing)...
Someone have a clue ?
Old Apr 25, 2018 | 02:24 PM
billib1954's Avatar
billib1954
make sure the tabs are engaged in the ts switch. easy to knock loose.
Old Apr 27, 2018 | 03:12 AM
Frédéric CM
it's not only the TS switch, but all the switches that are movings
Petiej
Electrical/Lighting/Alarm
Aug 21, 2019 06:12 AM
soulpatch
May 27, 2019 01:14 AM
Thumper26
Sep 13, 2016 08:42 AM
ployus
Jul 14, 2015 02:51 PM
LKHA
2014-2024 Touring Models
Dec 29, 2014 09:25 PM
