Twin cam 88 internals
Old Apr 26, 2018 | 07:14 AM
nevada72's Avatar
nevada72
Originally Posted by Nomadmax
But why not?????
Yeah....why not? Especially when his advice on this thread is ****. Go ahead and see what happens when you put a gear drive on a 2006 crank.
Old Apr 26, 2018 | 08:09 AM
multihdrdr's Avatar
multihdrdr
At the risk of getting OFF Track
Originally Posted by domcat74
... Were some upgrades done internally with the 06 that are shared with the 96” motor?
Hydraulic Tensioners...2006 Dyna 88
Old Apr 26, 2018 | 09:01 AM
joe40x's Avatar
joe40x
Originally Posted by VT81
GET RID of those original ANEMIC and worthless H-D cam chain tensioners and cams- .....and go to an S&S Gear Driven Cam setup along with an S&S Camchest setup.....you'll be free for many miles and smiles of non issues and other anomolies related to that original cam chain and adjusment shoe scenario
Maybe you can do the work for him in your "shop" unless you're just to busy with your police, fighter pilot, dd2114, 81, riding around the equator on your S&S (Square and seement) tires or celebrating anyone of your 9 birthdays?
corliss@bakerdrivetrain.com's Avatar
Originally Posted by seniorsuperglideE8
Gear drives are the cat's meow if you within the shaft run out for this particular set up. The tolerances escape me right but I'm sure some helpful member will chime in. I put in a 95" kit with some SE203 cams, this upgrade helped with two up riding then we got a touring model also had a hybrid cam plate with better oil pump and hyd. cam chain shoes installed for longevity. I think I'm done with that engine. It's an 02 FXD and I won't get back what I've put into it, great bike though.
You don't want anymore than .003" crank run out when using gear drive cam. Now keep in mind Harley now allows up to .012" run out in the bike.
Old Apr 26, 2018 | 09:08 AM
cvaria's Avatar
cvaria
sandbagging Mark, went are you announce the winners of the free 7-speed DD7? i haven't seen any emails....
Old Apr 26, 2018 | 09:11 AM
multihdrdr's Avatar
multihdrdr
Did you mean to post this in the other thread?
Old Apr 26, 2018 | 09:16 AM
cvaria's Avatar
cvaria
no, mark is here
for the sake of the thread:
2006 was an odd duck year for dynas
  • Hydrualic tensioners
  • 6 speed
  • 88" (Displacement, bore x stroke: 1450cc, 95.2 x 101.5mm)
Old Apr 26, 2018 | 09:19 AM
joe40x's Avatar
joe40x
deleted
Old Apr 26, 2018 | 09:23 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Subscribed....
multihdrdr's Avatar
multihdrdr
no, mark is here
Hmm..wasn't he just there 20min earlier
The "past" is the "past" ...wheather it's 7 or 20 min
