Security system
Old May 4, 2018 | 06:04 PM
Banjo Mike's Avatar
Banjo Mike
6th Gear
Default Security system
Hi just found out I have a security system on my 2002 low rider,it obviously is disarmed or otherwise I would've had troubles starting. I have no fobs.Can I check the pin number without a fob?just in case something goes **** up and have to override it.
Or as it is now off,will it stay off,if that makes sense. There is a siren plugged into the system fitted under the seat.
Any help would be appreciated, tho I'm happy to leave it as it is,but don't fancy any problems in the future..
Kinda just need to get my head around the set up.
Old May 4, 2018 | 07:53 PM
robarosa's Avatar
robarosa
My 2005 has a key light in the gauge when armed. I don't use the security (no key light) and just ride. It's pretty involved talking about the security system so do a hdforum.com or internet search for a 2002 owner manual in pdf form. Maybe on Harley's site. You'll find it. Good to have.
Edit:
Check this out.
https://serviceinfo.harley-davidson....cle/lookupForm
Old May 5, 2018 | 11:40 AM
Banjo Mike's Avatar
Banjo Mike
6th Gear
Edit:
Check this out.
hi thanks ,my key light only pops on briefly when I switch the ignition on,but not when the bike is off,no key in,
so I guess it's letting me know there is a system there,but not active,
which suits me fine.
Bonez76
Screamin Eagle CVO Models
Jan 27, 2018 07:23 PM
trike1
Electrical/Lighting/Alarm
Aug 9, 2014 09:10 AM
01flhtc
Jun 22, 2013 07:00 PM
TennesseeMustangPerf
Oct 1, 2011 08:15 PM
Rott3n
Apr 10, 2006 01:24 AM
