2002 Wide Glide build
Old Jun 5, 2018 | 01:36 PM
Sweetglide08's Avatar
Sweetglide08
Default 2002 Wide Glide build
Just ordered the 98" fuel moto kit and have a few questions, hopefully some carb guys still around. In lieu of the 98 kit I obviously need some other enhancements. I was thinking a Mikuni 42 kit and already ordered a pingel single outlet no vac petcock. What ignition would anyone recommend? I was looking into dynatek, trying to do this on a budget. Also need to beef up the valve springs for the 555-6r cams. Budget in mind just swapping valve springs and a little die grinding probably? Also wanna convert to chain drive and was looking into the zippers kits seem to have everything needed for a decent price. Also I'm in Colorado so this combo will run at mile high altitude. Any tips or advice is appreciated! Thanks!
Old Jun 5, 2018 | 01:39 PM
Sweetglide08
forgot to add, not the bike in my profile. Its a 2002 FXDWG with about 33,000 and my tensioners were scary low so she's getting a boob job and should run well
Old Jun 5, 2018 | 09:54 PM
Dyna100's Avatar
Dyna100
The stock CV will work fine with a few very inexpensive mods. Do you know what your compression ratio will be ? I used the Dynatech on mine and it works great.
Old Jun 6, 2018 | 01:39 AM
Sweetglide08
I still want to switch to the mikuni even if its just for easy reliability. CR says 10:1 on the kit. And which dynatek do you have? I was looking at the tc88 on ebay and a couple similar ones.
Old Jun 6, 2018 | 08:50 PM
Dyna100's Avatar
Dyna100
I used the Twin Tec TC88. Just curious, why would you think the Mikuni is more reliable ?
Old Jun 7, 2018 | 10:09 AM
Carl '69's Avatar
Carl '69
At your altitude with the Mik, any significant change in altitude when riding is gonna mess with your jetting/tuning, unlike the CV. CV40 will easily support 100hp, so if you absolutely have to have a bigger, "better" carb, you can pick up a CV44 for ~$250 new. CVs are also dirt simple to tune.
papaduke187
Carburetor Related
Oct 23, 2021 04:18 AM
Jox818
Feb 2, 2016 11:17 PM
Badtip1550
May 18, 2013 04:15 PM
Storm 4 U
Exhaust System Topics
Oct 22, 2007 07:37 PM
Maddogs700srx
Dec 19, 2006 04:27 PM
