High Idle
Old Jun 25, 2018 | 10:57 AM
JVR's Avatar
JVR
Default High Idle
2006 FXDI (Dyna Super Glide) has high idle after running on the road for a while. Some time must stop to let Idle return to near normal. Cleaned IAC and throttle area. No mods to engine.
Old Jun 25, 2018 | 02:01 PM
Huggerbugger's Avatar
Huggerbugger
MAP sensor?
Old Jun 25, 2018 | 02:50 PM
iaminsider's Avatar
iaminsider
Intake manifold leak?
Old Jun 25, 2018 | 03:43 PM
SixDD's Avatar
SixDD
From: Depends on who wants to know.........and why.
Mine is having this same problem. I have not tried cleaning the IAC yet. Let me know what you find out, please and thanks!
I'll do the same and let you know. New IAC maybe?
Edit: I have not gotten around to cleaning the IAC but I read that one trick is that as you spray the carb cleaner into the IAC opening you should have the ignition turned on; spray the cleaner and cycle the run/stop switch. As you cycle the run/stop switch the IAC will move back and forth letting you get all the sludge out.
Old Jun 25, 2018 | 05:38 PM
JVR's Avatar
JVR
Are you sure?
Old Jun 25, 2018 | 08:16 PM
BMyers's Avatar
BMyers
Mine did that, it was slight drag from the throttle lock
grayburg
General Topics/Tech Tips
Oct 28, 2016 10:58 AM
Lawrence Walrabenstein
Exhaust System Topics
Jun 9, 2012 04:13 AM
swanie
May 19, 2010 08:28 PM
ggibson
Nov 12, 2008 07:12 PM
valkal
Aug 18, 2008 09:34 AM
