Compensator clunking.
Old Jul 11, 2018 | 10:16 AM
Red Dragons's Avatar
Red Dragons
Wait, I thought the SE comp was standard before '14. I'm almost positive my '13 came with SE.
Old Jul 11, 2018 | 10:23 AM
Krazy8s's Avatar
Krazy8s
I think it became standard with the 2013 model.....
Old Jul 11, 2018 | 10:24 AM
Red Dragons
That's what I thought too.
Old Jul 11, 2018 | 10:39 AM
brownie4412's Avatar
brownie4412
Originally Posted by Kingglide549
It is hard to convince people they dont need the junk.
I was skeptical at first, then I talked Baker's tech support and they told me exactly what I said to the OP. That's good enough for me.
Old Jul 12, 2018 | 07:22 AM
Notgrownup's Avatar
Notgrownup
If you have Cush drive on the rear wheel, elimination of the compensator shouldn’t be a problem.
Old Jul 12, 2018 | 08:05 AM
Lambda's Avatar
Lambda
If your compensator isn't worn, you probably will be fine by just replacing the spring pack, I had to replace mine a few weeks ago because it was weak, the compensator itself had zero wear.
Old Jul 12, 2018 | 09:07 AM
Simplespeed's Avatar
Simplespeed
I'll look into that. Thank you.
