Hi yal,
i have a 97 Dyna Super Glide,
the issue is my indicators blink on idle, but as soon as I give it just the slightest rev they stop and stay on. I’ve replaced the turn signal module and all bulbs are the same watt, the wiring is all good along with the connections,
they still blink on hazard mode as well so there is no problem with the module.
Is there a way of re setting the module to extend the revs or distance before they turn off?
Or is it a speedo censor ? Even though the speedo works fine.???
I would take a wiring diagram and trace the wires front to back. Turn signals, speedometer, speed sensor, turn signal module. I would check each connector for corrosion and integrity. I would also include a close look the handlebar switches.
