Vinner error!!!
Old Aug 7, 2018 | 01:51 PM
toryhardin92's Avatar
toryhardin92
Default Vinner error!!!
On going problem.
2016 FXDB, short shots, heavy breather, has a nice dyno tune using the old race tuner.... I don’t have the tuner, it was not sold with bike. I don’t recall having hard start/vinerr error in the first 5,000 miles of owning the bike.
Symptoms:
Vinner code use to pop up occasionally and has gotten worse over the last month.
2 times out of the last 5,000 miles my bike stalled when coming to a stop. I can prevent this with giving it gas so it doesn’t die. If I kill the bike, and turn back on, problem goes away.
3. Has stuck on high idle for a few seconds at times when coming to a stop.
Things I have done/test results:
1. I cleaned the IAC with MAF cleaner twice and since then it seems to have an idle dying problem. But no guarantee considering I am still pulling this VINERR CODE.
CHARGING SYSTEM TEST RESULTS:
BATTERY before any testing sits at: 12.7v
Idle: 14.10
AND @ 2,000rpm: 14.15
Connections and grounds are all right and clean..
REGULATOR TEST:
1. Switched multimeter over to AC and connected leads to battery terminals and I am pulling 30.1 AC to the battery!!!
2. Multimeter lead to battery ground and to regulator plug, also saw voltage there which is no good.
STATOR TEST: (3 phase)
1. STATOR is not grounded. Good!
2. AC OUTPUT: 18-20 @ idle, 34-40 @ 2,000 rpm
3. Resistance: 0.6 ohms on every wire...not sure if that is high but all of them read the same...
MY QUESTION:
1. The regulator is shot according to my test results but would a bad regulator cause a VINERR code and not wanting to idle at times ?? Has anyone had a similar problem???
2. Does my resistance on my stator seem okay?
thanks everyone for your input.
Old Aug 8, 2018 | 09:54 PM
archergodwin's Avatar
archergodwin
How many posts do you need to create for the same damn issue?
Your charging is fine... if you're getting above 14 to your battery when running.
Yes, the resistance on your stator is fine.
check all your battery cables for tightness.. .both ends.
Old Aug 8, 2018 | 10:16 PM
jeffro09's Avatar
jeffro09
Get a new battery
Old Aug 8, 2018 | 10:35 PM
fxdfpants's Avatar
fxdfpants
Originally Posted by jeffro09
Get a new battery
This. Had the same error. Replace battery. Error has never returned.
Old Aug 9, 2018 | 01:28 AM
WHS's Avatar
WHS
me too.
Got one of those Advanced Gel Mat ones. Problem sorted.
Old Aug 9, 2018 | 07:52 AM
toryhardin92
That’s odd. Just because you are above 14V does not mean your charging system is “fine”
I had 14.1 V while running the bike and the same amount when at 2000rpm. So in fact it wasn’t charging anything.... that’s a very bland statement..
I had to replace with new regulatory and new battery in order for my bike to sit at a healthy 14.4 at idle and a bit higher at 2,000 rpms. That eliminated the VINNER and sluggish start..
And to your comment about the post, been riding since I could walk. I have made 3 post on this forum in the last 6 years about a problem I am capable of solving but really would like some input. Not all post are the same. Hell, I wish I saw more similar error post or troubleshooting post when I use this forum. I don’t think it’s a problem. Hopefully you are not on a Harley Facebook page. You would have pulled your hair out by now with the repetitive questions. Appreciate the input.
Old Aug 9, 2018 | 07:55 AM
toryhardin92
Get a new battery
New battery didn’t do it. I needed a regulator and battery! Just hoping my test results for my stator are good. Would hate to damage new regulator and battery.
98hotrodfatboy
Electrical/Lighting/Alarm
Jun 24, 2019 09:16 AM
Temeculacvo
Sep 9, 2015 07:51 PM
cnnesseth
May 5, 2014 11:18 AM
flhtc04
18
Apr 3, 2014 04:28 PM
skooter2000fb
Nov 15, 2012 11:04 AM
