96ci Motor Tap???
Old Aug 25, 2018 | 09:56 AM
SMG22's Avatar
SMG22
Stage III
Default 96ci Motor Tap???
What’s up everybody,
My 07 SuperGlide Custom just started making a horrible sounding tapping noise coming from the motor. I haven’t been able to pin-point the specific area that it’s coming from.
Please, take a listen to the video and tell me what y’all think. Any insight would be appreciated.
Thanks
Old Aug 25, 2018 | 10:03 AM
crusader1xxx's Avatar
crusader1xxx
Sounds like a heat shield rattling around. Have you tried putting a gloved hand on the heat shields to see it that would stop it. Some times you have to just grab and hold a few things to eliminate the "outside" items that can rattle. Once the outside is eliminated, then you can think inside noises....
Have you tried putting a stethoscope on it?
Narrowing it down to left/right etc helps as the video is not clear
Old Aug 25, 2018 | 10:12 AM
SMG22's Avatar
SMG22
Stage III
I’ll see what I can do as far as eliminating anything external. If that doesn’t help I’m planning on picking up a mechanic’s stethoscope at some point this weekend
I appreciate the reply man.
Old Aug 25, 2018 | 11:08 AM
tcazes's Avatar
tcazes
mighty metallic. id think heat shield as well. check the full length of the exhaust system
Old Aug 27, 2018 | 07:07 AM
POOK_HD's Avatar
POOK_HD
After checking that the heat shields are tight front to back, I'd check that the headers are still firmly attached to the engine. Those nuts can back off the studs causing the flange to start banging on the exhaust port or the studs. I would think it would be louder than in your video, but it can be hard to tell in a video.
Drail
Sep 30, 2018 08:24 AM
Patches513
EVO
Sep 15, 2018 03:30 PM
bbqbrisket
Exhaust System Topics
Apr 3, 2018 09:02 AM
pjim
Feb 7, 2015 06:05 AM
schwangster
EVO
Jul 14, 2013 03:29 AM
