Yep, might not be turning them enough. I don't recall you being able to turn them too far, just a single point pivot. Then the back side lifts up then you can pull it out pulling towards the tail lights.
You're fine, pull those tabs all the way back towards you, providing you're standing behind the bike. Its a tight snug fit as it should be, then just lift up on the back and slide the front out, if that makes sense. as far as the backrest, you should have 4 bolts holding the backrest and the luggage rack, just remove them, slide the shorter backrest out, add the new longer one in, your good to go.
