Wheel and axle question
Old Sep 11, 2018 | 05:43 PM
BigTuna's Avatar
BigTuna
Stage I
Default Wheel and axle question
I'm in the process of building my 2007 superglide into a Frankenstein of sorts. If swapped the mid glide trees out for fat bob l and have aquired a set of 2004 fatBOY wheels that i am attempting to fit. Here lies my problem. 04 wheels are 3/4 axle bearings whilst the axles on my SG are 1 inch. I am looking for a source for the inner bearing sleeve that will work for the wheels. Does anyone know the part number for Harleys 1,inch sleeve or know a manufacture selling them. Local dealership is worthless and has no idea what I'm trying to do.
Old Sep 11, 2018 | 06:03 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Welcome to the site!
Old Sep 11, 2018 | 08:46 PM
crusader1xxx's Avatar
crusader1xxx
Hi, doing wheel swaps myself ( should be a separate forum section on this) ..but I do believe Harley makes a kit...not sure on the part numbers though....and welcome to the forum
Old Sep 11, 2018 | 08:54 PM
crusader1xxx
You might be looking for this
Part Number 43848-08A
you will have to look into it , to make sure it fits, but I believe this is it, 1” wheel installation kit
Old Sep 12, 2018 | 05:39 AM
AFMM3's Avatar
AFMM3
I have done a bit of Frankenstein wheel swaps in the past and have learned some lessons the hard way. There are basically three types of front hubs that H-D uses. Narrow (used by mid-glides), wide (used by wide glides and electra-glides) and FL Softail. The Fat Bob front end will accept either 1 inch or 25mm axles and any modern wide hub, even the brakes will line up. An FL Softail front hub is off on it's own and will only work on FL Softail front ends. I am talking bolt on applications.
I have used both Fat Bob and FL Softail front ends on my Street Bob/Duo Glide build and made all the mistakes along the way.
tunafisher729
Feb 13, 2018 09:42 PM
stephtell
Shovelhead
Aug 2, 2015 04:10 AM
McGinnes_john
May 29, 2012 08:51 PM
sportsternoob
Wheels/Tires
Feb 23, 2012 07:01 AM
jammer1
Jul 1, 2007 08:33 AM
