Tire pressure Michelin Commander 2
A very rough way to arrive at a reasonable pressure is to take the weight rating of the tire and divide it by the maximum pressure, then multiply the result by the actual load on the tire.
The manufacturers tend to recommend higher pressures than optimal for a very good reason.
If you run tire pressures that are too high, and the resulting reduction in traction results in a crash, you can't sue anyone, because the motorcycle didn't fail, and the tire didn't fail- YOU put too much air in the tire and operated the motorcycle beyond it's reduced capabilities.
If you run the tire pressure too low (like only having 5 PSI cold) and the tire fails, then that opens the door for the question of whether the tire failed because of a defect in manufacturing or design. They can't question the tire pressure, because there's no way to measure air that exited the failed tire and left the scene of the crash.
Are you trying to say that setting your cold tire pressures low enough to allow the tires to come up to proper operating temperature, is somehow a bad idea?
In this case, yes, it is bad "advice". There is no single arbitrary tire pressure that is correct for every rider, on every tire, in every riding circumstance.
That's why I took the time to type out the information on determining correct cold tire inflation pressures based upon pressure rise from cold to hot.
Let's say that you're shooting for a 4 PSI pressure rise from cold to hot. The first morning, your tire pressures are 30F/30R cold, and you end up with 40F/40R hot. That's a 10 PSI increase- that's too much.
So the second day, you try 33F/33R cold, and end up with 38F/38R hot. That's a 5 PSI increase. You're getting closer.
On the third day, you try 34F/34R, and end up with 38F/38R hot. That's a 4 PSI pressure rise from cold to hot, which is what you were shooting for.
Lets not even get into having good measurement equipment and using it correctly. Then we need to discuss what gas goes into the tire...dry nitrogen, dry air, wet air, argon, CO2... Check the charts for them. They all react differently.
Yawn.
Under pressure motorcycle tires ( especially the rear) get very hot. I have seen one particular brand chunk and come apart if they get to hot while running low pressure. Most just wear to quickly or very evenly. Harleys usually have one wheel that leaks more than the other and on mine its the front. I make it a point to check tire pressure several times a week.
As cggorman said you also need a good way to measure the tire pressure. Invest in a good dial gauge. Like many of us I keep a cheap pencil type gauge on the bike for quick checks but those are notoriously inaccurate.
IMO if your bike rides to harsh with tires set at proper pressures you need different tires or better suspension.
Back to the OP's question. I would set that tire to 40psi in rear and 30psi front for your bike with CMII 's.
WOW.... to much coffee
