Check engine light
Old Sep 17, 2018 | 05:37 PM
Stewart Rubin's Avatar
Stewart Rubin
Stage I
Default Check engine light
I have a 2005 Dyna low rider with fuel injecton, when my speed is over 65 the check Engine light comes on , don’t no how to fix , I need help
Old Sep 17, 2018 | 06:57 PM
mmesa005's Avatar
mmesa005
Start by checking DTC codes https://www.hdforums.com/forum/softa...des-dtc-s.html
Old Sep 20, 2018 | 11:14 PM
texuspete00's Avatar
texuspete00
If my check engine light stays on a second or two after start... Does that mean something without needing a fancy doohickie to check codes? I could swear it's a light check when you first start, but every once in awhile it sticks around a few ticks.
Old Sep 20, 2018 | 11:33 PM
mmesa005's Avatar
mmesa005
CHECK ENGINE LAMP
When the lamp turns off after being illuminated for the first four-second period, it will:
a. remain off if there are no fault conditions or trouble codes currently detected by the Ignition Control Module.
b. come back on for an 8-second period if only historic codes exist.
c. come back on, and remain on, if a current trouble code exists.
Kyle C Kirk
Nov 9, 2015 02:13 PM
AdrianVall
Sep 6, 2011 04:44 PM
tekeum
Jul 14, 2010 08:55 PM
SE120RG
Jul 20, 2009 08:00 AM
20NightTrain03
Jul 6, 2006 12:00 AM
