Looking for an aluminum style that can be emptied out rather than the normal filter into the atmosphere. DK Customs are on back-order, but a similar style is what I'm after.
It has a removable foam baffle inside, the bottom unscrews to access it for cleaning. Available at the usual places, Amazon, J&P Cycles, and of course Kuyrakin direct.
Any reason why you can't wait for DK's backlog to clear? Not really something you'd need at this moment...IMO. You could call them & see if they'll add a discount to cover your wait...??
True, yeah I don't need it ASAP or anything, no purchasing more till this coming Friday anyhow so I'll give them a shout first and see what's up.
Going to rig up something soon. My fat bob has been spitting oil through the heavy breather since new cams. I'm going to take some oil out of if & see if that helps.
But the idea of the motor sucking in oil & blowing through the intake doesn't sit well with me. I thinking of just running some hose from the breather bolts to the ground.
Now if only I can manage to remove the decorative covers that hide the breather bolts. Tired prying off the covers with a screw driver with no luck. Time maybe for vice grips.
Anyone run into the same problem?
No, I can usually wiggle mine off by hand but worst case a screwdriver or pocket knife pops them out. The o rings on the caps may be dried up and stuck, when you get them off lightly oil them before reinstall.
Or use Magic Lube, a PTFE based O Ring Lubricant / Sealer ... Aladdin Brand ...Easy to find at any swimming pool supply house. Or at Amazon
