feels like bad swing arm bushings
Old Oct 22, 2018 | 09:03 AM
PDB17UltraRG's Avatar
PDB17UltraRG
Welcome to the Forum lots of great info here enjoy and learn from Stuart Fl. Ride a Lot Ride Safe. Start with a good tire inspection it dozen take much to do what your going threw.
Old Oct 22, 2018 | 10:46 AM
Huggerbugger's Avatar
Huggerbugger
Is there a hum when you do curves? If the wheel bearings are deficient, you'll usually get a warning as a hum.
Old Oct 22, 2018 | 04:22 PM
1st time HD owner's Avatar
1st time HD owner
Default swing arm bushings
tires are good air pressure 30 psi.
OK I'm going to try to add extra washers and squeeze the rubber bushings together
and see if this will make a difference.
Old Oct 22, 2018 | 06:14 PM
fxrnutt's Avatar
fxrnutt
Rubber bushings?......I say get a manual before you touch it
Old Oct 23, 2018 | 09:37 PM
archergodwin's Avatar
archergodwin
4k miles... highly doubt it's the swing arm bushings... take a close look at your front motor mount.. .. I had to shim my original front mount and perform a vehicle alignment... cornered great after that.
Old Oct 24, 2018 | 02:23 AM
cggorman's Avatar
cggorman
Isn't 30 psi quite a bit low?
Old Oct 24, 2018 | 06:20 AM
Bob_fxdb's Avatar
Bob_fxdb
Maybe it’s a defect motor mount? That could give you a fishtail flex on the rear tire. But you only have 4K miles on it. Worth a check thoo
Old Oct 24, 2018 | 07:56 AM
archergodwin
lIke CGGorman said... 30psi is too low. A good place to start would be 35 up front and 38 in back.
Old Oct 24, 2018 | 02:25 PM
mds's Avatar
mds
6th Gear
too low pressure, on my wide glide, 35psi on front and 40 on the back.
Old Nov 3, 2018 | 02:24 PM
1st time HD owner
OK tires are good belt is good spokes and front mount are good
i stiffened the shock load and road it seems to be fine now
Thanks for all the good Advice.
