Intermittent Check Engine Light
Ive been getting a red check engine light when Im in higher RPMs 4200k and up. It is usually at higher speeds in 4th and 5th gear but it happened once in 3rd gear as well.
Usually its on for about 3 seconds then goes away. It usually disappears if I roll off the throttle. Additionally, I feel like theres been more vibrations in the floor boards.
I know it could be a million things, but any thoughts on obvious culprits that I should check? Thanks!
While you're at it check the plugs.
You should also see if the bike threw any codes, since the CE light came on.
After my engine build everything seemed fine, until... I don't remember the exact sequence of events, but I was on a full day ride and my engine light started coming on here and there, at higher speeds. It would go out if I slowed down for a bit, IIRC. Shortly after, I detected an extremely annoying clicking sound from my cam chest. There's excruciating detail in this thread, but I'll cut to the chase so you don't need to read it:
https://www.hdforums.com/forum/dyna-...-sound-10.html
Basically, it turned out that my inner cam chain had developed a tight spot (or spots), possibly caused by a damaged tensioner. In short, it would bunch up ever so slightly at the point of greatest tension, then spring back to where it should be. I've named the phenomenon "Cam Apnea." Sort of like sleep apnea, except instead of your breathing stopping for a moment, the front cam would stop turning for a fraction of a moment, then spring forward to where it should be (I mean a REALLY brief interruption). Once I changed the cam chain, everything came back to normal and the light never reappeared. I'm not exactly sure of everything that can trigger that light on a carbed bike, but my theory was the Cam Position Sensor. I don't know why it didn't throw the light at lower speeds, but maybe the issue didn't fully present itself until engine speeds and/or temp was above a certain point...
Hopefully not your issue...
But here's my two cents with warning lights (TPMS on cars is a good example): When an annoying light comes on, we tend to look for all the reasons that may cause the light to come on without good cause... But sometimes the light is actually telling you something you should know, and is coming on exactly as intended.
Good luck!
Knowing they had recurring issues causing their ommision soon after debut, I'd'd suspect the cam position sensor. Not sure if '01 had them or not, tho.
If all good check your plugs and plug wires. I would just change them anyway if they have not been done. Especially the wires. Most people ignore them but they do wear.
if after that is done and if it’s still a problem then look at the CPS etc.
