04 dyna low rider not starting
Old Jan 8, 2019 | 11:56 PM
Michelle Elizabeth's Avatar
Michelle Elizabeth
Stage IV
Default 04 dyna low rider not starting
04 dyna low rider twin cam
former owner abandoned in elements for over a year.
Did basic maintenance on 12/3/2018. New battery, terminal cables, sparks, oil/filter, fuel, fuses/relays, air cleaner filter. Started just great!
12/4- Would not start. Made clicking noises, lights flickered, fuel pump primed.
12/8- Replaced starter. Buttoned up exactly how it was with cables before break down. No click, no fuel pump prime, lights- dead. Checked voltage, battery 12V. Power going to starter and fuse box.
Noticed ignition switch wire was frayed, replaced on 1/8/2019. Still nothing .
Yall I'm absolutely stumped. What am I missing?
Old Jan 9, 2019 | 12:14 PM
nevil's Avatar
nevil
Start from square one. I know you put in a new battery but if it wasn't fully charged it could run down quickly. Before you start throwing any more parts at it, get the battery charged completely and get it load tested.
The ignition switch would be suspect, having sat outside for a while.
Old Jan 9, 2019 | 03:17 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Something basic, stop/run in run.
Old Jan 10, 2019 | 05:43 AM
madwrencher's Avatar
madwrencher
could have bad connection. I would check where the ground connects on the frame under the seat. Also have the battery checked.
Old Jan 11, 2019 | 05:21 PM
Michelle Elizabeth
Stage IV
this is how the terminals are connected to starter. It's how it was on the original. Think maybe if I connect the negative to the frame itll work? Gotta be some simple thing. I feel seriously stupid right now..
Old Jan 12, 2019 | 11:39 AM
skinman13's Avatar
skinman13
I had a 2001 FXD for years and my son has a 2004 FXDLI now that I work on and I am familiar with this starter system. This is how I would approach troubleshooting your problem as I understand it...
Put your volt meter on the small terminal on the starter to ground and see if you are getting 12 vdc when you are trying to start. You should read 12 volts at the small terminal when you have the master to run and the run/start crank switches to crank. If you read 12 volts at the small terminal when you are trying to crank and it still doesn't turn over, move your volt meter to the big terminal and make sure the volts do not drop below 10-11 volts. If you do not read 12 volts at the small terminal, then jump the small terminal to the big terminal with a piece of wire...if the starter solenoid and motor are good and you have good battery power with good connections, the starter will engage and turn over the engine period. Just make sure you are in neutral!
If your volt readings are good and it still does not turn over, then the starter has a problem. If the volts at the small terminal drop off when you attempt to crank, you probably have something going on with the master, start/run and or crank switches or wiring, probably one of the switches. If the volts at the big terminal drop off significantly when the circuit is energized, you probably have a bad connection, a failed starter, battery or all three.
Lastly, you probably should get a can of electrical cleaner and some silicone dielectric grease and clean and lube up connectors as you go...future insurance
Good luck!
J.M.B.
May 27, 2019 05:53 PM
Michelle Elizabeth
Electrical/Lighting/Alarm
Jan 12, 2019 08:39 PM
twincambill
Dec 8, 2017 07:27 AM
MISFIT-GRMG
Nov 4, 2017 08:19 AM
mike06train
Jul 6, 2011 10:36 PM
