FXDX Winter Suspension Project
The Motion Pro tool was super simple to use for steering neck race removal. Both of them popped right out:
I tried Multi's suggestion of finding a bearing puller in our shop at work (I work at a car dealer), but everything I found was bulky and seemed like it would interfere with the steering stops in the lower tree. I ended up picking up the Motion Pro tool to remove the race from the steering stem. Again, it worked well with no drama. I ended up placing it in my tube holder, just so I didn't have to hold the tree. the race came right off.
Question: Do I need to pull the stem out of the tree for powder coating, or just have it masked? I can remove the circlip, but it's pressed together and I'm concerned about it going back properly.
I now have both cartridges disassembled. Here's the view of the bottom end. The threaded piece is the compression valve. It needs to be pushed into the cartridge housing a bit, exposing a spring clip of a similar design to the clip on a piston wrist pin. Some people say the locating dimples must be drilled out, others say it's not necessary. Either way, exposing the clip requires about a half inch of clearance. I secured mine in such a way that the flange at the top of the cartridge was held steady by my wood jaws, and gently tapped the end with a 3/8 extension. Once pressed in, a tiny screwdriver easily extracted the spring clip.
And... Here are the two valves from inside the cartridge. Rebound is connected to the cartridge shaft, compression is sitting on the wood jaws.
That's it for tonight!
Think of all those take-off Trees getting PC'd ... think they're pressing out those stems?
As a side note ... Now that the bearing is off, think about which direction you would have pressed that stem out ... Then measure the diameter of the stem on each side of the Trees and tell me if you just changed your thinking ... Counterintuitive to some. I think it's the Snap Ring that throws them off
Guess you'll just use those as your alignment grooves when going back together
Btw, some/most of the later cartridges don't have those dimples ("later" as in the fairly recent stuff)
Here's the stock FXDX spring specs, as far as I can find (if anyone knows better, I'm all ears):
Outside Diameter: 30mm
Length: 432mm (17")
Rate: 6.0 Newtons (.61 Kg)
Closest Ohlins offering I can find:
Length: 380mm
Rate: 8.0 Newtons (.82 Kg)
Race Tech offers the following:
Length: 330mm
Rate: 7.1 Newtons (.72 Kg)
Rate: 7.4 Newtons (.76 Kg)
Rate: 7.8 Newtons (.80 Kg)
Rate: 8.1 Newtons (.83 Kg)
Rate: 8.5 Newtons (.87 Kg)
Traxxion offers the following:
Length: 300mm
Rate: 7.3 Newtons (.75 Kg)
Rate: 8.8 Newtons (.90 Kg)
Rate: 9.3 Newtons (.95 Kg)
Rate: 9.8 Newtons (1.0 Kg)
Rate: 10.8 Newtons (1.1 Kg)
Now I'm not sure whether I should use the Ohlins offering, or whether I should be looking at Race Tech and Traxxion as well. I'm not sure whether the length differences between brands is a factor at all, since all of them will require spacers, but my not-super-educated mind can't help thinking the longer length of the Ohlins spring may equal more travel than the other two brands (no one seems to list travel in their specs).
Howard, if you're listening, please feel free to chime in! I will call you to discuss, but unfortunately won't be able to for several more days...
Bonehead Performance in Warminster, PA: https://boneheadperformance.com/
I went back and forth on the lower legs... Originally I selected Mirror black to match the trees and covers, but I called the next day and changed them to Heavy Silver. With black wheels, calipers, fork brace and black/carbon fiber fender, I decided I wanted some contrast. I used Heavy Silver on my lower rocker boxes and pushrod covers, so it'll match something. I think it's a pretty cool finish. But I'm a sucker for metal flake. In real life, it's a little lighter than it looks in this picture:
I filed them but should have modded them before. I was thinking that they would look good more rounded and cut off about 1/2 inch. Coupla holes would have been nice..
