Power commander 3 usb help
Old Mar 13, 2019 | 01:17 PM
Pfeiffe22's Avatar
Pfeiffe22
5th Gear
Originally Posted by DTTJGlide
Just wondering why you thought you had WB sensors instead of the stock NB sensors, if you have it should be near the PC3 as it plugs into it. Either way the new exhaust isn't different enough to cause a problem with the tune you have, just try it & see.
Thanks you! I will look a little closer when I get the chance. My step father knows a lot more about bikes than I do lol. I had a jap bike when I was younger but this is my first harley. He told me they looked like wb sensors because they are bigger than the nb sensors on his street glide. I guess I will just have to try it and see. They have a map for v&h short shots that might be close.
Old Mar 13, 2019 | 02:06 PM
DTTJGlide's Avatar
DTTJGlide
The early NB sensors were 18mm, so don't look too hard for the AT, I'd just try the map you have first, you can always try the other one. If you were switching to a 2-1 it might require a change, but 2-2 are quite similar so you should be fine.
Old Mar 13, 2019 | 02:12 PM
Pfeiffe22's Avatar
Pfeiffe22
5th Gear
Thanks a lot for the help. I talked to a couple guys and your rite about the o2 sensors. Hopefully once I get it set up it runs good and I don't have too mess with it.
Dans03RKC
Dec 31, 2015 08:58 PM
lakota1995
Dec 28, 2012 10:38 PM
BaggerSam
Feb 8, 2011 01:41 PM
Ford Lowrider
Mar 18, 2010 08:40 AM
Ford Lowrider
Mar 17, 2010 07:45 PM
