Dyno tune
Old Apr 1, 2019 | 11:20 AM
rons73's Avatar
rons73
Default Dyno tune
Hi,
wanted to get some feedback I recently had a SS 110 kit put on my 09 Street Bob. Also heads ported and machined and compression set to 10.7. Put HPI 55mm TB with 5.3gps injectors. I already had a woods cam TW-8-6 in my bike. Exhaust is new Thrashin AR 2-1 stepped. Was dyno tuned with Power Vision and both power & tq came out to 122.
I thought id get more with this build so just wanted some feedback from experienced people on here.
Thx
Old Apr 1, 2019 | 11:58 AM
nevil's Avatar
nevil
Post a pic of the dyno sheet, sometimes that can give a lot of clues as to what's going on.
Old Apr 1, 2019 | 12:04 PM
rons73's Avatar
rons73
heres the dyno sheet
Old Apr 1, 2019 | 02:54 PM
Nickd2689's Avatar
Nickd2689
To be honest I’m not very educated with dyno sheets but I’m at 122 tq on a se 117 kit (259e cams 9.9:1 comp, 5.3 injectors, and 58 mm throttle body). I also had it dyno tuned with powervision and have a fat cat exhaust. I thought I’d get more power out of my setup as well
Considering you had headwork done, I also would think you woulda gotten a little more power out of it, but I don’t think your numbers are low by any means sither
Old Apr 1, 2019 | 07:13 PM
14fxdwg's Avatar
14fxdwg
does it show the air fuel ratio ?
Old Apr 1, 2019 | 07:34 PM
rons73's Avatar
rons73
no it doesn’t
Old Apr 1, 2019 | 09:40 PM
Dyna100's Avatar
Dyna100
I have almost the same build and got 122 Torque. I think that's about right and figured that's what I'd end up with when I planned the build. To my knowledge, the biggest Torque factor is cubic inches and compression. Seems the porting, cams, etc helps more on the HP end.
Old Apr 1, 2019 | 10:33 PM
brownie4412's Avatar
brownie4412
You should post this in the Dyno Room. Someone hanging out in there will be able to decipher it for you.
Old Apr 1, 2019 | 11:16 PM
rons73's Avatar
rons73
good point will do
Old Apr 1, 2019 | 11:32 PM
Ghost_13's Avatar
Ghost_13
Hi,
Thx
Throttle body too small.., and the cam questionable
Ghost
