I found a minor leak on the back of my rear cylinder at the connection of the lower rocker box. I had ordered rocker box gaskets and went to work on the bike this weekend.
First thing I discovered is that I ordered upper set of gaskets instead of the lower gaskets, so that basically killed the job.
However, I decided to start taking things apart for when I actually do get the correct parts. I was following the manual but for the most part, the manual really didnt give much in the way of instructions.
What is the order of removing the gas tank? Do I plug anything up or just let it drip?
Second, I couldnt find anything on this forum or on youtube for removing the rocker box in the rear for the 103. Everything was a sportster which didnt help. How do you manage to get to everything in such a tight space? What is the order for removing things in there as well? The only information I found is that I need to rotate the rear tire in gear so the rockers are both in the lower position. Seems to be a lot of work for something that isnt really that detrimental and I could just leave alone.
Take out the front and rear tank bolts. Have someone gently lift the tank until some resistance is felt. Stuff a rolled up towel under the tunnel in the tank bottom. Voila! plenty of room to work on your rockers.
I was thinking about that, so I dont necessarily need to completely remove the tank? Also, is there enough room to get to all the bolts under the top rocker cover for the bottom cover right under the frame there>?
I didn't remove the gas tank, just undo the quick disconnect fuel line, loosen the front tank mount, remove the bolt from the rear mount and stuff an old towel between the tank and frame. I kept my front wheel straight so the upper triple wouldn't hit the tank while it was tilted up. Remove from top to bottom like in the diagram in the below link (upper cover> oil breather> rockers> lower cover). The rear is tight but everything can come out and go back in, you will have to put the bolts in the rocker assembly and move the bolts up and down while slipping it back into the lower cover, same on the breather.
Rock on(no pun intended), thank you for that information. Does anyone make just the bottom rocker gasket or do I have to buy it as a full set? Also, if I do take everything apart, do I need to replace all the gaskets anyway(negating the previous question)?
I replaced everything, didn't want to go back in there again for another leak.
Make absolutely sure that before you reassemble everything you blow out the oil that may settle down into the bolt holes. An air hose/nozzle, can of aerosol key board cleaner, Q-tips, anything. Those holes are sealed at the bottom. If oil is in there when you install the bolts it will have nowhere to go... "hydrolocked" and you may blow out the bottom of the hole/head. Take your time!
__________________________________________________ ____ For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
