B2262 Error Code
Old Aug 9, 2019 | 09:40 PM
28337's Avatar
28337
6th Gear
Default B2262 Error Code
Hi
I have B2262 error code (Front brake switch stuck) issue on my LRS '17 and have no more ideas how to fix it.
That what is done now:
- Checked my front break lever. It moves forward all the way. I sprayed piston with WD40, then put some lube on - now it returns better but breaklights are permanently ON
- Yesterday I left my LRS at OD shop, they replaced break switch with new one - breaklights are still ON. They pushed breaklever - nothing happens. Pushed breakswitch with finger - nothing happens.
- Switched OFF rear brake switch - nothing.
- They checked wires - looks OK
Now OD said it may be BCM problem.
Any ideas?
Thanks
p.s.: please excuse me for my English - it is not my native language
Old Nov 28, 2019 | 09:03 PM
Akhil Gopakumar's Avatar
Akhil Gopakumar
Stage III
Hi. Were you able to find a fix? Could it be the brake pads?
Old Nov 29, 2019 | 09:11 AM
BMyers's Avatar
BMyers
What's your thought process to surmise a stuck front brake switch would lead to the pads?
Old Nov 29, 2019 | 10:17 PM
Akhil Gopakumar
Stage III
It was a question based on what I randomly found on my bike. Found the pads to be worn along with this error. So just wanted to check if it had any relation before I start to troubleshoot. I'm quite clueless.
Old Nov 30, 2019 | 08:40 AM
user 7172984932's Avatar
user 7172984932
Deleted
Old Nov 30, 2019 | 09:17 AM
user 7172984932
Originally Posted by 28337
Hi
Any ideas?
Thanks
What was the fix? Helpful to let others know.
Old Dec 3, 2019 | 12:28 AM
Akhil Gopakumar
Stage III
Just figured it out. A small piece of double sided tape did the trick! There's a white switch which is released when the brake lever is pressed and that gets the light on. (Not the piston which goes into the master cylinder). It's on the fwd left part where the brake lever meets the handle area. That switch was not getting pressed while the lever was in normal position. So I put a small piece of double sided tape on the lever so that the button will be pressed. Then I cleared the error message and thats it. All fine now.
rotcart
11
Sep 3, 2017 07:55 AM
HarleyQC
2014-2024 Touring Models
Apr 11, 2014 07:51 AM
flhs
Powdercoat & Paint
May 19, 2012 06:20 PM
choochoo
Mar 8, 2007 09:57 PM
