Replacing Rear Wheel
Old Aug 12, 2019 | 02:53 PM
Jay Guild's Avatar
Jay Guild
Default Replacing Rear Wheel
Due to an untimely sprocket bolt failure I am having to replace the rear sprocket and wheel on my ride. So far I've got a new Harddrive chrome rear 70T sprocket, a 3/4" sprocket spacer (what was needed if not replacing the wheel but since I do a different spacer may be needed), some grade 8 bolts, and am looking at ordering a 16" x 5.5" big spoke rim and a 180/65 - 16 Night Dragon tire. Thinking I should order an axle spacer kit as I expect the hub width will be different. Anyone spot issues or other parts that I am missing? I plan to reuse the rotor.
Old Aug 12, 2019 | 08:52 PM
billib1954's Avatar
billib1954
Rotor bolts?
Cross thread points awarded.
Old Aug 12, 2019 | 09:29 PM
crusader1xxx's Avatar
crusader1xxx
Check out bluebob’s post on fixing this issue so it never happens again...
Old Aug 13, 2019 | 09:30 AM
Jay Guild's Avatar
Jay Guild
Yeah, the two of us have talked about it. I think the issues he found solutions for are not as prevalent in aftermarket wheels though as most I found don't have the counterbore for the pulley bolts. It is strange though that Harley put that counterbore in there but doesn't use bolts with a long enough shoulder to sink in the counterbore. Also, measuring the bore width in the new spacer and pulley has them at much closer tolerances to the width of the new bolts than the harley pulley did. I'll get some comparison measurements up soon.
Old Aug 13, 2019 | 02:32 PM
Jay Guild's Avatar
Jay Guild
Originally Posted by billib1954
Rotor bolts?
Points!
Good thought though. Might as well replace them.
Old Aug 13, 2019 | 07:35 PM
NORTY FLATZ's Avatar
NORTY FLATZ
You may have to shim the caliper or rotor if the rotor is moved. Based on the problems with destroyed wheels lately, I'd shim the caliper (reluctantly.)
Old Aug 14, 2019 | 12:07 AM
Blue Bob's Avatar
Blue Bob
It's interesting my last post offering to help Jay with his spacers seems to have been deleted?
I have offered to help many people on this forum with no charge not to drum up business but to just help?
Why would my post be deleted? I have no intension to become a business member?
Old Aug 14, 2019 | 12:18 AM
multihdrdr's Avatar
multihdrdr
Not this one?
https://www.hdforums.com/forum/dyna-...l#post18473531
Old Aug 14, 2019 | 07:59 AM
Jay Guild's Avatar
Jay Guild
Bob, that was in another thread where someone is using the same wheel as me. I saw where someone did have to machine down the width of the brake caliper to get the proper spacing and I may need to have that done. I appreciate the offer but I will talk to some friends that do machine work for Kelderman and John Deere here locally first.
Old Aug 14, 2019 | 08:03 AM
Blue Bob's Avatar
Blue Bob
Thank you multi...I must just be getting old.
