how did you get your front fender rolled back like that?
I ground and drilled out the rivits,reversed the mount and used button head bolts to secure the forward fender hole to the rear hole on the mount. This will hold the fender and I used a plug to fill the rear fender hole. Then mount the fender using the bottom hole on the fender tabs on the slider and rotate the fender into position and redrill the upper hole on the fender mount through the tab on the slider. Only cost is chrome bolts and nuts to replace the factory bolts on the slider,if you want to do that.
TOMMAY
Lookin Good as always.... I'd really like toget that headlight bracket...Where did you find it at ???
Thanks for your time..
Hi Ronn,good to hear from you. I've always admired your bike,when I redo mine again I might go with the look you have on your bike including the floorboards.
Got the h-lite bracket from Dennis Kirk,don't have the part number with me,my computer is down at home,I'll post it later. I got the part number on here but I can't remember who posted it.
Thanks TOMMAY for the kind words.. I've always felt the FXDBI headlight was set back a little too much.. Looks good on you and Chips ride.....
Chip thanks for the part numbers...........
Ronn
Used the same post/bracket for my headlight with some of those visors on my turnsignals, and was thinking of moving 'em down to the forks - good to see what they look like there - thanks for the pics!
Chip
I used the same bracket for my headlight.
Bike is looking good Tommay
TOMMAY
Good Luck
Tom
Looks Great TOMMAY !! I alwaysfind it interesting to see what you've donecause I've seen your bike in person.I tooneed that headlight blockpart # ... that's next on my list.
Hope all is well down your way !!
