03 Wide Glide Electic Issues
Old Sep 4, 2019 | 01:30 PM
cody96ss's Avatar
cody96ss
Stage IV
Default 03 Wide Glide Electic Issues
Was riding on a warm and dry day when speedo and odometer started flickering. When I would let off the throttle it would work, when I would get back into it, they’d go out. Stopped, let her sit for a couple of minutes, fired it back up and made it about two likes before it started bucking and sputtering so I killed it. Never got it to refire.
Got it home for testing. No headlight, no odometer, no turn signals, no start. If I jump the battery to the starter solenoid with the power switch on it will start and run. Any ideas!?
Old Sep 4, 2019 | 03:09 PM
Blue Bob's Avatar
Blue Bob
Have you load tested the battery? Just checking with meter can be misleading and not show true condition of battery. Slow charge overnight and load test and check charging system.
Also check all ground connections while your at it.
Old Sep 4, 2019 | 03:14 PM
Hoginedgewood's Avatar
Hoginedgewood
Thanks for letting us help you!
Old Sep 4, 2019 | 03:36 PM
tygr1's Avatar
tygr1
I, too was thinking intermittent ground somewhere. But what do I know?
Old Sep 4, 2019 | 07:49 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
When checking the grounds, tug on the cable going into the lug. Had a Sportster do the same thing and found the cable going to the starter had two strands left in the cable.
Old Sep 4, 2019 | 08:18 PM
crusader1xxx's Avatar
crusader1xxx
More than likely it’s your battery cables....make sure they are clean and tight....clean and tight. Clean them even if they look good...
Old Sep 4, 2019 | 09:16 PM
REW13's Avatar
REW13
Been chasing a tach issue for a year here.... Some times is works. Sometimes it don't!
But I shift by feel so don't need it.
But good luck finding your issue, please post so I can check it with mine.
Old Sep 4, 2019 | 09:20 PM
John CC's Avatar
John CC
Yeah, could just as easily be one of the positive cables as the grounds.
Old Sep 6, 2019 | 02:09 PM
cody96ss's Avatar
cody96ss
Stage IV
Default Update
Battery good and fully charged. Terminals and connectors cleaned.
No headlight, no odometer, no turn signals, etc still. However when I switch the headlight to bright, the blue indicator comes on but no light. Horn works, brake light works, stereo works. Can start the bike by jumping to the starter so I’m going to do that and go ride until something happens...
Old Sep 6, 2019 | 02:29 PM
cody96ss's Avatar
cody96ss
Stage IV
Default Update again
Took it for a ride. Once it dies, if I don’t cycle the ignition before I jump the starter, then it will not start. But if I turn it off, back on, then jump the starter, it will start again. Did this 3 times on the 20 minute ride.
