08 Dyna low rider 96ci 6speed. I need a new frame. Will be using all of my same parts .What years and sub models are the same or will have direct fitment Dyna super glide/ wide glide / street bob.
Superglide, Switchback, Street Bob, fat bob are all the same as long as it’s 2006 and newer...the two others are the low rider and the wide glide. I know the neck rake is different then all the others on the wide glide, the one I am unsure of is the low rider...
Low rider has the same as the rest. Only wide glide is different
All the Dyna's from 2006 and up will work, but the Wide Glide does have the 34 degree rake instead of the 29 degree rake on the rest. You could put fork extensions on with the Wide Glide frame to keep the ground clearance the same but end up with a longer stance and a little different trail.
Fat bobs and wide glides are wider between the rear struts.
id be looking for street Bob, low rider or super glide frames
And on the FatBob frame specifically, you cant use a regular jack straight up, you need adapters because the frame rails are different. Ask me how frustrating this was.
