Difference between 13.5 inch shocks and 14.2 inch shocks
Old Oct 3, 2019 | 11:08 PM
Bob_fxdb's Avatar
Bob_fxdb
Originally Posted by John CC
Not sure what this has to do with the topic at hand, but, have you tried loosening all the bolts holding the exhaust in place and adjusting it a little, before retightening things, in the correct order?
It was just a explanation/comparison on the oem and aftermarket motor mount, or just my experience
But anyways, I just can’t see how I could lower the exhaust and then bolt it in again to specs without it going back to the original position
Old Oct 4, 2019 | 07:47 AM
John CC's Avatar
John CC
Well, it happens. I'm guessing the exhaust was installed (or readjusted) after the mount had started to collapse, so it is positioned correctly for the sagging engine. Try it or not, your choice. If you decide to, use the tightening procedure supplied by the exhaust manufacturer. If it didn't matter they wouldn't have one.
Also, make sure the foot peg bracket is correctly positioned. I never figured it out, but when I got my Dyna, the bracket was touching the exhaust and the brake pedal could not be adjusted to my satisfaction. When I took it apart and put it back, everything changed and all was good.
Old Oct 4, 2019 | 08:35 AM
TOE_CUTTER's Avatar
TOE_CUTTER
Originally Posted by F86
If your spring rate or preload (or both) are too soft in the shocks, you may not actually be maintaining the full height expected in all conditions...
This along with what is the length and spring rate of the front forks? With a stock style front end, most go 1 to 2 inches over stock length. Did ODC build your suspension for your weight and riding style? The suspension has to be a little stiffer if you’re riding it like track day on the street.
Dave
Old Oct 4, 2019 | 08:48 AM
TOE_CUTTER's Avatar
TOE_CUTTER
Cycler,
What pegs do you have?
Dave
Old Oct 6, 2019 | 12:56 PM
GREENOHAWK69's Avatar
GREENOHAWK69
0.7 inches.
Old Oct 6, 2019 | 01:02 PM
multihdrdr's Avatar
multihdrdr
Originally Posted by GREENOHAWK69
0.7 inches.
Finally
Old Oct 6, 2019 | 08:50 PM
John CC's Avatar
John CC
Wait a minute, what was the question?
CSS899
May 8, 2021 06:24 AM
armydgp
Dec 7, 2017 06:56 AM
JayOhh
Oct 20, 2016 06:28 PM
ebeattie
Jun 19, 2013 01:21 AM
gbb
Jun 17, 2013 04:29 PM
