Belt Width 1" or 1-1/8"
Old Nov 27, 2019 | 07:15 AM
JoeeJoee's Avatar
JoeeJoee
Default Belt Width 1" or 1-1/8"
Hey Guys, have a 30 tooth front pulley going to a 70 tooth rear pulley, been running a 68 tooth rear with my stock 1" belt no problems. When I change to 70 tooth rear going to use a 2 tooth longer belt, and finally the question. Should I go ahead and fill pulley with the 1-1/8" wide belt or stay with a 1" belt, just wondering? Going on a 16 FXDB, Thanks!
Old Nov 27, 2019 | 01:20 PM
John CC's Avatar
John CC
Going up 2 teeth on the pulley only requires one additional tooth on the belt. (The belt only goes half way around the pulley).
Old Nov 27, 2019 | 02:01 PM
cggorman's Avatar
cggorman
I assume the concern is strength...
The narrow belts have proven themselves up to the task of most (if not all) the engine builds suitable for street use. 130hp easy.
How hot (powerful) is your engine?
Planning super sticky drag launches?
Old Nov 27, 2019 | 05:33 PM
JoeeJoee's Avatar
JoeeJoee
Thanks, trying to center the rear wheel adjuster with longer belt. The 70 tooth pulley on stock belt pulled the adjuster to far forward. Thanks for the info on belt length, i"ll check on a 132 tooth belt. Not a drag racer and no wheelies although I do push it. Built it for hills, valleys and curves, oh and the fun factor. Engine is a 103 puts out 100hp / 110tq. Seems the 1" is more than adequate.
Thanks again, Joe
P51Driver
2018+ Softail Models
Jun 26, 2019 05:39 AM
128auto
May 7, 2013 11:15 PM
blackflame
Jul 9, 2012 04:37 PM
ozzy07840
May 7, 2010 05:23 AM
96 Wide Glide
EVO
Oct 3, 2009 04:12 PM
