disc centering in caliper mount bracket
Old Mar 31, 2020 | 05:48 AM
mirrmu's Avatar
mirrmu
Default disc centering in caliper mount bracket
Hi,
so i destroyed my rear wheel from a bearing failure, 2010 fxdwg
have now got a 2015 streetbob rear wheel which is same part number I believe, from checking on Ronnies it looks like will fit my 2010 ok.
have changed rubber, pressed in bearings etc and fitted up
the rotor is just touching the left side of the caliper mount bracket and needs to move right about 1-1.5mm (after alignment, belt tension check and axle nut tighten)
whats the best way for this now, can you shim brake rotor? or get new left and right axle spacer (this will move pulley over too?)
thnks
Old Mar 31, 2020 | 01:17 PM
Jay Guild's Avatar
Jay Guild
I'd check to see if the wheel is centered first. If it is then a shim spacer should work. If not look for better fitting axle spacers.
Old Mar 31, 2020 | 03:24 PM
mirrmu's Avatar
mirrmu
Thanks Jay, will check service manual
Wondering if the crush tube maybe smaller as well between the wheels. Get started on getting the wheel off.
Br125
Jun 14, 2016 06:27 PM
5 speed
Apr 30, 2016 06:02 PM
800screws
EVO
Dec 24, 2014 02:16 PM
Ratmobile
Aug 8, 2014 01:58 PM
0734
EVO
Jul 19, 2014 03:00 AM
