Headlight trim ring
Old Apr 27, 2020 | 01:18 PM
snake_eyes's Avatar
snake_eyes
Default Headlight trim ring
WTF are you supposed to use to hold that little nut on the headlight trim ring? I tried using my smallest crescent wrench since a socket won't fit, but I still can't get a good bite on it!
Old Apr 27, 2020 | 01:48 PM
R_Einan's Avatar
R_Einan
I hold the nut in place with my thumb and start the screw, once the screw starts to thread the nut stayed in place against the trim ring while I screwed the screw. If that doesn’t work for you a pair of needle nose vice-grips would likely work.
Old Apr 27, 2020 | 02:02 PM
shodown220's Avatar
shodown220
Poster above me nailed it. You don't use a tool on that nut. Just hold it with your thumb and start the screw on the other side and it will catch and hold
Old Apr 27, 2020 | 02:03 PM
Blue Bob's Avatar
Blue Bob
Ditto
Old Apr 27, 2020 | 02:18 PM
snake_eyes's Avatar
snake_eyes
Mine spins. I tried using my thumb and it still spins. I'll try a needle nose vice grip. Thanks guys
Old Apr 27, 2020 | 08:24 PM
multihdrdr's Avatar
multihdrdr
Which way do you have the tapered part of the nut facing?
Old Apr 28, 2020 | 08:25 AM
snake_eyes's Avatar
snake_eyes
Same way it came off, fat side to the trim ring, tapered side out.
Old Apr 28, 2020 | 08:57 AM
multihdrdr's Avatar
multihdrdr
"fat side to the trim ring, tapered side out."
Well ... that's your problem
Old Apr 28, 2020 | 09:31 AM
snake_eyes's Avatar
snake_eyes
Are you shitting me?
Old Apr 28, 2020 | 09:50 AM
multihdrdr's Avatar
multihdrdr
I guess that could be the same question if someone said they couldn't tighten their headlight trim ring nut
