Bent Highway Bar
Old Nov 22, 2021 | 07:26 PM
TownesVanZandt's Avatar
TownesVanZandt
This was 6 months ago, maybe hes still beating on it with a hammer though?
Edit: not mention.... 35lb plate? cmon, should have only 45's, 25's, 10s, and 5s
Old Dec 27, 2021 | 05:53 AM
vonh12's Avatar
vonh12
Had a buddy at auto body shop straighten mine took 15 minutes. Looks new.
Old Sep 15, 2024 | 04:56 PM
Back_Away_Slowly's Avatar
Back_Away_Slowly
New Member
Default Ratcheted straps will do the trick!
Originally Posted by user 839202
So, here's what I did. Instead of duck walking my bike down the driveway between the cars - like I should have - I decided to slowly cruise down the middle of the driveway.
I was going pretty slow and it looked like I had plenty of room. This is why I don't lane split - because I'm not experienced enough to get down my 20 foot driveway without bouncing off $50k worth of vehicles.
Anyway, as you can see from the giant photo, the front left tire on the civic (on the left side of the picture) is turned out just enough that I hit it with my left highway bar. That made me bounce off the tire and hit the bottom of the door of the Volvo (right side of the picture) with my right highway bar and the side-view mirror with my right handlebar.
At the time, I had no idea that I hit the civic. I thought I just hit the Volvo. Until I got halfway down my street and tried to shift up into second gear. The toe of my boot is now hitting the left highway bar. Also when I rest my feet on the foot-rest when riding, my feet are not equal distant - my left foot is noticeably closer than my right.
The bike rides fine - did just under 200 miles today - and I couldn't tell a difference in the ride. Except when I shifted and my toe hit the highway bar. I highly doubt the frame is bent at the tab because I was going so slow when it happened.
So...I've done some reading and saw a couple of methods for bending crash bars back into place. What is your tried and true method? I've tried pushing on it with my foot while seated on the bike but I consistently skip leg day...
Thanks...
If anyone's still watching this thread - you can use a similar technique to what I just used to put a highway bar on my Vulcan 800. It was just about 1/4" too high to bolt onto the holes where the horn mounts at the top. So I took two ratcheted moving straps and hooked onto opposite ends of the bar and cranked it down until they squeezed into position. Photos aren't very good, but I've attached.
Fetasigma
Aug 1, 2017 10:21 AM
dbc58
Sep 16, 2013 12:32 PM
C. Numb
May 21, 2009 10:42 PM
Bryan53
Aug 28, 2008 12:01 PM
grinner
May 1, 2007 05:11 AM
