Brake light does not work streetbob
Old Jun 28, 2020 | 11:51 AM
  #31
falikmike's Avatar
falikmike
ok i finixhed the diagnosis
When I unplug rear cables, the stop light shuts off, and the front brake turns the stop light on if I press the lever....
I connected the cables also for rear switch and the light comes up.....so obviously the problem in in rear brake switch...
where to find the exact brake switch for my street bob 2014? on ebay I saw some for year 2005 etc....
Old Jun 28, 2020 | 11:52 AM
  #32
wastedranger's Avatar
wastedranger
Dealer nearby?
Old Jun 28, 2020 | 11:55 AM
  #33
Jay Guild's Avatar
Jay Guild
Maybe try some wd40 on the switch and exercise it a bit. It may just be stuck in the on position.
Old Jun 28, 2020 | 11:56 AM
  #34
falikmike's Avatar
falikmike
do I need to unscrew it? then the brake fluid will come out
Old Jun 28, 2020 | 12:00 PM
  #35
wastedranger
Don’t think this will work on the rear.
Old Jun 28, 2020 | 12:54 PM
  #36
falikmike's Avatar
falikmike
this one is the right fit? You see how it has wire attachments at the end? and that one on page 1 does not have
https://www.ebay.co.uk/itm/Harley-Da...UAAOSwGdJe9z6c
Old Jun 28, 2020 | 01:11 PM
  #37
nevil's Avatar
nevil
I don't know about the one on ebay, but here is the switch from the parts book. It's #45
https://partsfinder.onlinemicrofiche...R%20W/%20PEDAL
Old Jun 28, 2020 | 01:36 PM
  #38
wastedranger
I’m confused. The only picture of a brake light switch in this thread is the correct part you need. It even includes the correct part number. Now if you haven’t determined that with the brake light disconnected you can or can’t replicate the results in the video I sent the link to I’m not positive it’s the rear switch.
Old Jun 28, 2020 | 01:56 PM
  #39
Jay Guild's Avatar
Jay Guild
You're right. The rear switch actuates on the fluid pressure and not a physical piston like the front. Luckily a rear switch only costs $12
Old Jun 28, 2020 | 04:06 PM
  #40
John CC's Avatar
John CC
If you aren't comfortable changing the switch, just leave it unplugged. How often do you brake with just the rear brake?
