Shock fell off while riding
Old Sep 4, 2020 | 07:21 AM
SC07Bobber's Avatar
SC07Bobber
Default Shock fell off while riding
Bad luck. I took a ride and within 2 miles, I heard a bang/crash. My right side shock was on the pavement sliding along next to me. I carefully pulled over and walked back to retrieve the shock in the road.
Upon examination of my bike, I noticed the upper shock bolt snapped off inside the strut mounting hole. I also observed that the lower shock bolt, spacer and the actual shock bushing were still mounted on the bike. Very odd. The entire lower shock bushing stayed with the bike; so the shock had actually slipped off and over the bushing and lower bolt.
Luckily, I was close to home and no other damage to bike.
The recovered shock had scrapes and road rash and obviously no lower bushing.
Cause unknown. I didn’t bottom out or hit any potholes. It happened just after a slight, and I mean slight dip.
I was able to extract the sheared upper bolt.
Major bummer.
Old Sep 4, 2020 | 07:37 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
My theory:
Shock was loose, finally causing the bolt to snap.
Hanging shock finally worked it`s way off the lower bushing.
Old Sep 4, 2020 | 07:38 AM
lespaul6's Avatar
lespaul6
Wth? that's odd for sure... you better play the lotto today.
Old Sep 4, 2020 | 07:41 AM
kel03's Avatar
kel03
Very odd, thanks for posting, any pics
Old Sep 4, 2020 | 07:52 AM
SC07Bobber's Avatar
SC07Bobber
Not sure what pics will show other than what I described. It’s a bike with a removed shock.
I’m not trying to be sarcastic.
Old Sep 4, 2020 | 08:01 AM
TexasScooterTrash's Avatar
TexasScooterTrash
Right shock top bolt snapped on my 07 too. A few months later my Riding Buddy had the same bolt snap on his 07 Dyna. Replaced the grade 5 with a grade 8 bolt on both shocks. Problem solved.
Old Sep 4, 2020 | 08:09 AM
SC07Bobber's Avatar
SC07Bobber
So I’m not alone. Wow. Well I guess that’s why the moco went to the stud design the next year.
Old Sep 4, 2020 | 11:59 AM
470004's Avatar
470004
Glad you did not lose control of the bike when it happen.
Old Sep 4, 2020 | 05:16 PM
cggorman's Avatar
cggorman
Not uncommon on certain years. The top stud has changed a few times. The early ones seem the strongest, the middle ones weakest, and the later ones good enough.
the lower bushing loss is just because the shock hit the ground and twisted/whipped around so violently that it blew out the bushing.
Old Sep 4, 2020 | 11:38 PM
Bone Doc's Avatar
Bone Doc
When it fell off, I bet that was quite a shock . Sorry, couldn't help it.
