Difference between 99-00 dyna
Old Sep 11, 2020 | 07:09 PM
carr612's Avatar
carr612
Default Difference between 99-00 dyna
Whats up guys after quite a while of looking and getting back into the stunt world this time on a harley im between a 99 lowrider and a 00 superglide iv heard the 00 88TC is different from the 99 88TC can anyone shed some light?
they are both carb motors
Old Sep 11, 2020 | 10:17 PM
TexasScooterTrash's Avatar
TexasScooterTrash
99 was the last year of the nosecone ignition. 2000 was the 1st year of the Ctankshaft trigger ignition.
Old Sep 12, 2020 | 07:50 AM
R_Einan's Avatar
R_Einan
I believe that is incorrect, my ‘99 has the same ignition module mounted under the seat on the primary side as the ‘00. It does have a cam position sensor under the timing cover however. The ‘99 uses Evo era single piston calipers vs the 4 piston on the ‘00+, and I don’t recall if they switched to sealed bearings in ‘00 or ‘01.
Old Sep 12, 2020 | 07:56 PM
Gearhead88's Avatar
Gearhead88
The engine was almost all the same , the cam drive was updated ( recall ) , due snapped cam retension bolt issues , with that came updated bearings too . There was never a nose cone ignition but there was a cam position sensor for the first few years , during this time they figured that a cam position sensor was uneccessary and was no longer used , I think starting in late 01 or 02 , the cam sprocket was changed to a different part at the time they dropped the cam sensor . The rest of it is the same , including time proven timken bearings in the sprocket shaft side.
As for chassis differences the brakes are different , the wheel bearings are different , the timken servicable wheel bearings went away and starting in 00 und up vehicles being sealed bearings and with that , some vehicles started to be delivered with larger axle sizes , starting with touring models , Dyna's after that. .
The engines that had nosecone ignitions in 99 were softails and sportsters , the softail TC - B engine was released for the 2000 model year , injected or carb'd
Handsome
Oct 23, 2019 05:16 PM
buford1488
Jan 17, 2014 09:08 PM
wolfydude
May 17, 2012 09:18 AM
JokerRides
Jun 20, 2011 01:03 PM
schmeg
Feb 7, 2008 08:51 AM
