Dyna streetBob compression
Old Sep 21, 2020 | 08:15 PM
AlexH4ll's Avatar
AlexH4ll
Stage I
Default Dyna streetBob compression
hi i have a Dyna streetBob 2007 (all stock and not oversised)
i would like to know
good compression psi?
bad compression psi?
bad difference compression psi
i will really apreciate if someone can help me thx
Old Sep 22, 2020 | 12:43 AM
Birtyyy's Avatar
Birtyyy
140 psi is good. 110 psi is borderline. 10% or more difference between the two cylinders is bad.
Old Sep 22, 2020 | 07:13 AM
Paul-S's Avatar
Paul-S
My 08 FXDF 96" was 190/190 stock.
Old Sep 22, 2020 | 11:45 AM
nevil's Avatar
nevil
I can't take the suspense. What are your compression readings?
Old Sep 22, 2020 | 10:24 PM
Birtyyy's Avatar
Birtyyy
Stock is supposed to be about 165
Old Sep 22, 2020 | 11:03 PM
Blue Bob's Avatar
Blue Bob
It depends on the cams and how many revolutions.
Leak down test is also important.
Old Sep 23, 2020 | 08:32 AM
John CC's Avatar
John CC
Dynamic compression checks are going to be all over the map. All the factors above, plus the properties of the gauge itself come into play. Consistency is the most telling quantity you'll get.
A leak-down (static) compression test can tell you a lot more about the actual health of the cylinder(s), if you're really concerned.
Big_O
Exhaust System Topics
Jul 29, 2019 08:10 PM
hrdtail78
Dyno Charts
Feb 16, 2018 01:23 PM
malibuss
Jan 11, 2010 02:39 PM
OhioSkully
Oct 24, 2009 03:14 PM
freebyrd
Sep 19, 2008 11:31 AM
