How do i adjust my shocks?
Old Jul 28, 2007 | 10:23 AM
JRK5892's Avatar
JRK5892
Default How do i adjust my shocks?
So i installed a air ride on my bike and let me tell you it is AMAZING!!! i took my old shocks off and put them on my brothers Sporty... LOOOKS SICK but rides like a hardtail now, How do i adjust them to make them softer. I see all those holes on the bottom of the shock and want to make sure they are both the same setting, thanks for helping this idiot out!
Old Jul 28, 2007 | 10:53 AM
BluRooster's Avatar
BluRooster
Default RE: How do i adjust my shocks?
There's a flat wrench made out of Alum that looks like an open claw. You need that. The holes at the bottom of the shock are usually decoration...
http://reviews.ebay.com/Shock-Adjust...:-1:LISTINGS:4
Old Jul 29, 2007 | 07:28 PM
JRK5892's Avatar
JRK5892
not with the shocks on my bob... what way to i turn them to lower them? (make them softer)? I have the correct tool
Old Jul 29, 2007 | 09:23 PM
speedjunkie's Avatar
speedjunkie
My lowrider has numbers associated with certain holes. 1-5 IIRC. 1 being softest, 5 being stiffest. I just tried to stiffen mine up from 2 tonite with the HD tool, and it boogered up one of the holes, so I'll look again, maybe I'm an idiot, but that's the way I see they are adjusted as well. I'm currently looking for a spanner that has a round pin instead of a square pin to go in a round hole. So, DON"T adjust anything yet!!
Mike
Old Jul 29, 2007 | 09:30 PM
mud's Avatar
mud
ORIGINAL: speedjunkie
junkie, why not just file the corners off??
mud
Old Jul 29, 2007 | 11:25 PM
speedjunkie
Yeah, I'll probably try that next. It was getting dark and hot in the garage this evening, so when things went wrong, I decided to step away for awhile and get some advice here. Good thing too, now I've got a direction to go again in the morning. THANKS!!
Mike
Old Jul 30, 2007 | 09:41 AM
speedjunkie
Ok, that's what I did. Took a file to the edges and rounded them off. The spanner now has a nice continuous radius that matches the radius on the shock. Tried it out, works like a champ! I did put a piece of tape on the flat area that touches the shock to prevent scratching tho. Thanks again for the advice. Carry on!!
Mike
Old Jul 30, 2007 | 10:02 AM
Oldandslow's Avatar
Oldandslow
A different option is to buy a belt wrench (Sears and other places). They wrap around anything you want turned. Especially nice for shocks as the rubber belt won't mar the surface. Good for plumbing connections, also.
Old Jul 30, 2007 | 05:47 PM
JRK5892's Avatar
JRK5892
so to get a softer ride what way do i turn them? it is not marked on the shock at all?
Old Jul 30, 2007 | 08:23 PM
pfb's Avatar
pfb
Just adjusted my Dyna rear shocks.
FYI, the BMW 1100GS shock wrench fits and works perfectly. Might be helpful info when if you ever want to adjust on the road sometime... Just track down a big dual-sport beemer and ask if you can look in their toolkit!
